[Qgis-user] QGIS Keybindings
Hugh Kelley
hghklly at gmail.com
Mon Oct 4 09:17:16 PDT 2021
Got it, thanks,.
Maybe I'm a little outdated calling them keybindings.
It's clear how to assign new keybindings, for instance I searched for
"vertex tool", clicked change, and then tried Control + D. Was given a
warning that Control + D is assigned to "Remove Layer/Group".
I tried the save button to see if I could pull a list of existing shortcuts
from the xml but the file is empty, so I guess it does not include defaults.
Maybe there's an xml file with the default settings in the repo somewhere?
On Mon, Oct 4, 2021 at 12:03 PM Zoltan <zoltans at geograph.co.za> wrote:
> Presumably you have looked at Settings->Keyboard Shortcuts ?
> The trick would be to extend the available list on that sub-menu to
> include items that are not listed there.....
> (Let me know when you find out how)
> Regards,
> Zoltan
> On 2021-10-04 17:45, Hugh Kelley wrote:
> Hi all,
> I periodically need to make extensive edits to vector datasets in QGIS.
> It would be very helpful to have keybindings that allowed me to switch
> between the drag map extent, select, edit vertices, draw feature and maybe
> a few other cursor types.
> Web searches don't turn much up. I did find this:
> https://defkey.com/qgis-3-shortcuts, but that doesn't seem to have what I
> need.
> thanks for any suggestions about an alternative workflow or custom
> keybindings or what not.
> Hugh Kelley
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Zoltan Szecsei GPrGISc 0031
> Geograph (Pty) Ltd.
> GIS and Photogrammetric Services
> Cape Town, South Africa.
> Mobile: +27-83-6004028 (Signal, not WhatsApp)www.geograph.co.za
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211004/70c6f4ce/attachment.html>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211004/70c6f4ce/attachment.xml>
