[Qgis-user] QGIS Keybindings
Charles Dixon-Paver charles at kartoza.com
Mon Oct 4 09:25:02 PDT 2021
Hi hugh, the "export defaults" as a part of the XML is a feature that has
been added to the latest release 3.22 which will be available later this
month, or you could use a nightly build. IT will include PDF exports as
well.
On Mon, 4 Oct 2021 at 18:23, Hugh Kelley <hghklly at gmail.com> wrote:
> Got it, thanks,.
> Maybe I'm a little outdated calling them keybindings.
> It's clear how to assign new keybindings, for instance I searched for
> "vertex tool", clicked change, and then tried Control + D. Was given a
> warning that Control + D is assigned to "Remove Layer/Group".
> I tried the save button to see if I could pull a list of existing
> shortcuts from the xml but the file is empty, so I guess it does not
> include defaults.
> Maybe there's an xml file with the default settings in the repo somewhere?
> On Mon, Oct 4, 2021 at 12:03 PM Zoltan <zoltans at geograph.co.za> wrote:
>> Presumably you have looked at Settings->Keyboard Shortcuts ?
>> The trick would be to extend the available list on that sub-menu to
>> include items that are not listed there.....
>> (Let me know when you find out how)
>> Regards,
>> Zoltan
>> On 2021-10-04 17:45, Hugh Kelley wrote:
>> Hi all,
>> I periodically need to make extensive edits to vector datasets in QGIS.
>> It would be very helpful to have keybindings that allowed me to switch
>> between the drag map extent, select, edit vertices, draw feature and maybe
>> a few other cursor types.
>> Web searches don't turn much up. I did find this:
>> https://defkey.com/qgis-3-shortcuts, but that doesn't seem to have what
>> I need.
>> thanks for any suggestions about an alternative workflow or custom
>> keybindings or what not.
>> Hugh Kelley
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Zoltan Szecsei GPrGISc 0031
>> Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> Cape Town, South Africa.
>> Mobile: +27-83-6004028 (Signal, not WhatsApp)www.geograph.co.za
> Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211004/e68c0831/attachment.html>
