[Qgis-user] QGIS Keybindings
Mathieu Gillot
mathieu.gillot at larbre-ingenierie.fr
Tue Oct 5 00:46:29 PDT 2021
For what it's worth, I'm using a hardware solution with a programmable
keyboard that maps standard keyboard shortcuts (or all kinds of key
combinations). Which, after a little learning time, allows you to switch
from one tool to another very smoothly and considerably improves the
workflow.
There are professional solutions for this kind of tools (very expensive),
but I personally use a l *** tech G13 keyboard (gaming accessory, no longer
manufactured but easily found on occasion) whose driver (under Windows)
allows good customization (in addition to adapted software profiles). There
are newer similar keyboards but I can't comment on that.
This allows you to completely dispense with the standard keyboard (except
for entering data), and eliminates the need to go back and forth on toolbar
buttons.
Extremely useful under other CAD software, eg autocad.
Le lun. 4 oct. 2021 à 18:25, Charles Dixon-Paver <charles at kartoza.com> a
écrit :
> Hi hugh, the "export defaults" as a part of the XML is a feature that has
> been added to the latest release 3.22 which will be available later this
> month, or you could use a nightly build. IT will include PDF exports as
> well.
> On Mon, 4 Oct 2021 at 18:23, Hugh Kelley <hghklly at gmail.com> wrote:
>> Got it, thanks,.
>> Maybe I'm a little outdated calling them keybindings.
>> It's clear how to assign new keybindings, for instance I searched for
>> "vertex tool", clicked change, and then tried Control + D. Was given a
>> warning that Control + D is assigned to "Remove Layer/Group".
>> I tried the save button to see if I could pull a list of existing
>> shortcuts from the xml but the file is empty, so I guess it does not
>> include defaults.
>> Maybe there's an xml file with the default settings in the repo
>> somewhere?
>> On Mon, Oct 4, 2021 at 12:03 PM Zoltan <zoltans at geograph.co.za> wrote:
>>> Presumably you have looked at Settings->Keyboard Shortcuts ?
>>> The trick would be to extend the available list on that sub-menu to
>>> include items that are not listed there.....
>>> (Let me know when you find out how)
>>> Regards,
>>> Zoltan
>>> On 2021-10-04 17:45, Hugh Kelley wrote:
>>> Hi all,
>>> I periodically need to make extensive edits to vector datasets in QGIS.
>>> It would be very helpful to have keybindings that allowed me to switch
>>> between the drag map extent, select, edit vertices, draw feature and maybe
>>> a few other cursor types.
>>> Web searches don't turn much up. I did find this:
>>> https://defkey.com/qgis-3-shortcuts, but that doesn't seem to have what
>>> I need.
>>> thanks for any suggestions about an alternative workflow or custom
>>> keybindings or what not.
>>> Hugh Kelley
>>> Qgis-user mailing listQgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Zoltan Szecsei GPrGISc 0031
>>> Geograph (Pty) Ltd.
>>> GIS and Photogrammetric Services
>>> Cape Town, South Africa.
>>> Mobile: +27-83-6004028 (Signal, not WhatsApp)www.geograph.co.za
>> Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211005/45f943fa/attachment.html>
