[Qgis-user] PDF output of QGIS: features disappear
Nyall Dawson
nyall.dawson at gmail.com
Mon Oct 4 17:20:59 PDT 2021
On Mon, 4 Oct 2021 at 17:16, Uwe Fischer <gisfisch at t-online.de> wrote:
> Hello List,
> I have to create a PDF map which contains air photos and vectors. With QGIS 2.14.2 (which I still run for certain reasons) it works fine, the output PDF is about 96 MByte and contains all the features. But the PDF is not georeferenced (which is important for use in Avenza).
> So I opened the exact same project file in QGIS 3.18 and saved it to a new qgz file. Then repeated the print composer PDF export. Now, the output is geolocated, but there are vector features missing in an unpredictable way (please see attachment, blue arrows).
Can you open a bug ticket with a reproducible test case demonstrating this?
Nyall
