[Qgis-user] Incredibly slow attribute view/access from postgresv3.16
Richard McDonnell richard.mcdonnell at opw.ie
Wed Oct 6 02:12:38 PDT 2021
Andrew,
Maybe what you need to do is Filter the data before editing, removing all but the data you are looking to edit.
Another thing you can try in the Attribute Table is Show Features Visible On Map, I have not tried it but, you can set this as the default behaviour by going to Settings, Options, Data Sources and under Feature Attributes and Tables set the Attribute table behaviour to Show Features Visible on Map.
I hope some of the above helps.
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrew Hughes
Sent: 06 October 2021 08:22
To: Bernhard Ströbl <bernhard.stroebl at jena.de>
Cc: QGIS User <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Incredibly slow attribute view/access from postgresv3.16
Thanks Bernhard,
I'm afraid we are quite well indexed. I'd also expect slow performance on the map rendering if that were the problem.
Unless of course there is some client side data caching from postgres that I am not aware of?
Thank you & Cheers,
Andrew
On Wed, 6 Oct 2021 at 16:26, Bernhard Ströbl <bernhard.stroebl at jena.de<mailto:bernhard.stroebl at jena.de>> wrote:
just a few ideas: Do you have a spatial index on the table?
I have no clue how QGIS handles the attribute table (loading all
datasets in the first place and then select or else) maybe editing this
many features is better done directly on the DB?
Bernhard
Am 05.10.2021 um 23:51 schrieb Andrew Hughes:
> Hi All,
> Just to get this out the way... *I don't believe this is a problem with
> the primary key or its index. *
> I have a postgis datasource with approx 3 million features (road
> segments). Yep, lot-a-data.
> The rendering performance is ok & visible @ 1:50,000+ . Takes a few
> seconds but hey, it's a lot of data and certainly not disappointing.
> However, severe performance problems are seen whenever I am trying to
> work with anything related to attribution, such as "Open Attribute
> Table" or "modify the selected features or all attributes
> simultaneously". We're talking around 10 minutes of "/Not Responding/".
> Note: I have altered the QGIS "/Settings -> Options -> Data Sources ->
> Feature Attributes and Tables/"    so that "/Show selected features/" is
> now the default attribute table behaviour. So _hopefully_, this doesn't
> attempt to load all 3million features.
> Can anyone offer any guidance as to what I might be able to do to track
> down this issue (or just fix it)? For reference, we are trying to put
> together a simple editor that will allow a user to browse, select (road
> segment) features, and edit a single text attribute value on all
> selected features only. Fairly simple, but the UI elements we need
> appear to be in a world of pain.
> Thanks in advance,
> Andrew
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
> __________ Information from ESET Mail Security, version of virus signature database 24076 (20211005) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 24078 (20211006) __________
http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211006/3d020fc8/attachment-0001.html>
