[Qgis-user] mapping bus routes
Andreas Neumann
a.neumann at carto.net
Thu Oct 7 23:54:37 PDT 2021
Besides on what was discussed here on the list already, I can add the
following information: the Swiss QGIS user group has mandated Nyall
Dawson to carry out a couple of days of research exactly on this topic -
kind of a feasibility study if it would be possible to draw such network
maps "on the fly" / automatically - with transit maps and hiking maps
(multiple parallel hiking routes) in mind.
I believe Nyall will work on this before the end of the year.
Of course we cannot promise anything - but based on the outcome of this
study, there might be follow-up work pending. If there is interest from
other users we might want to organize an institutional crowd funding
initiative.
This won't help you immediately - but it might be good for you to know
that the problem is on the radar. If there is a positive outcome in the
study, there might be implementation work pending next year.
Greetings,
Andreas
On 2021-10-07 23:53, David Strip wrote:
> For a transit map, it seems the offset would not be constant. Consider
> two bus routes that overlap along a single street in their routes. On
> that street, the two lines typically would be offset to opposite sides
> of the line representing the street. On the rest of the route, however,
> the route would be shown as lying directly over the centerline, not
> offset to either side. Life gets even more complicated when multiple
> routes overlap with different numbers of other routes at various points
> on the map. Or at least that's what I've typically seen on transit
> maps.
> On 10/7/2021 3:30 PM, Nicolas Cadieux wrote: Hi,
> You can also trim the lines in the symbology (at least in QGIS 3.20) as
> well as giving it an offset. That will insure that intersection are
> not overlapping in the offset.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 7 oct. 2021 à 17:23, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a
> écrit :
> Oups! Forgot the list...
> Nicolas Cadieux
> écrit :
> Hi,
> You can automatically draw an offset by adding a offset in the
> symbology. Things get more complicated when line vectorization changes
> directions as the offset flips side depending on, for example, if the
> line is drawn from A to B or B to A.
> In the QGIS models, https://plugins.qgis.org/, go to models then Fix
> Directional Network models 1,2 and 3. That will help you find problems
> (like disconnected lines) but also identify all the lines that are
> flipped. You can then flip them manually or figure out an algorithm to
> do it automatically.
> You will also find a boring YouTube video on my YouTube channel.
> https://youtu.be/v61PafSByvM
> Nicolas Cadieux
> Le 7 oct. 2021 à 14:17, Hugh Kelley <hghklly at gmail.com> a écrit :
> Hi all,
> I'm wondering if anyone has any good tricks for mapping bus routes. The
> key problem is defining how to offset lines where the routes overlap.
> I've handled this by chopping up the lines and offsetting in postgis
> according to some st_dwithins and st_intersections but wanted to see if
> there is anything in the wide world of QGIS that I'm not aware of.
> My understanding is that it's a fairly significant challenge to do a
> great job with it. A company called transitapp had an interesting blog
> post about it a while ago.
> https://archive.transitapp.com/transit-maps-apple-vs-google-vs-us-cb3d7cd2c362#.e9kcryzg1
> Hugh
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211008/f5c38e52/attachment-0001.html>
