[Qgis-user] Filter in field group sections of report
    Jésahel Benoist
    djes1975 at gmail.com
    Sun Oct 10 14:20:06 PDT 2021
Hi Yann,
As I'm often using reports based on filtered datas, and as I see that you
know how to filter, I don't really understand what is the problem. You can
just apply a filter in the main ui on the a or b layer, or make virtual
layers with only the needed datas. Then use the report (close when a change
is made in the main ui).
Regards,
Jésahel
Le dim. 10 oct. 2021 à 18:53, Yann Voté <ygversil at lilo.org> a écrit :
> Hi everyone,
> Let's imagine we have a polygon layer named Layer A with tons of
> features (tens of thousands), and an attribute layer named Layer B with
> even more features. Each polygon in Layer A is associated with one or
> more rows in Layer B.
> Now suppose we have created a report with a top section for Layer A
> containing a map centered at each polygon, and a subsection for Layer B
> showing attributes for each related B row.
> Is there a way to output the report for exactly one polygon in layer A,
> or for only some polygons (for example selected polygons) ?
> And is there a way in the subsection to output only some of the related
> rows based on some filter expression ?
> I am aware of this feature request
> https://github.com/qgis/QGIS/issues/44821
> but is there a way to achieve this with more steps in the UI or with
> pyQGIS ?
> Thanks a lot !
> Regards.
> Yann Voté - ygversil at lilo.org
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211010/dd2142b4/attachment.html>
