[Qgis-user] Celestial map
Hernán De Angelis
variablestarlight at gmail.com
Wed Oct 13 00:36:22 PDT 2021
Mathematically it is very simple, one only needs to multiply the X
coordinates by -1. I am not that familiar with the QGIS Python console
to suggest a method there, but I am almost convinced there must be one.
Perhaps other users can give you a suggestion on this.
/H.
Den 2021-10-13 kl. 09:13, skrev Lester Anderson:
> Many thanks for the pointers Hernan, and clarity on the
> correct orientation of the map.
> I do have constellation boundaries and the asterisms as shapefiles,
> but these are oriented the normal way, e.g. Orien is on the left and
> not the right as you mention. Cannot see an easy way of flipping these
> files.
> Lester
> On Tue, 12 Oct 2021 at 17:10, Hernán De Angelis
> <variablestarlight at gmail.com> wrote:
> Lester,
> Yes, it can be done. I believe you need to do some preprocessing
> on your star data to convert RA to degrees (which you wrote you do
> not want to do but is not difficult). I also guess you are aware
> that RA coordinates (or the x axis) have to be mirrored for use in
> geographical software because RA increases to the left, as opposed
> to normal longitude which increases to the right. It will probably
> be some work with the styles and proper scaling of point sizes to
> star magnitudes.
> /H.
> Den 2021-10-12 kl. 13:56, skrev Lester Anderson:
>> Hello,
>> Is there a simple way of plotting star charts using Right
>> Ascension and Declination, with proper scaling, without
>> converting Right Ascension to degrees?
>> Would like to create both a rectangular plot and North South
>> polar plots.
>> Thanks for any pointers
>> Lester
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211013/2339b55d/attachment.html>
