[Qgis-user] QGIS 3.20 Crash
Stefan Giese (WhereGroup) stefan.giese at wheregroup.com
Mon Oct 18 00:51:23 PDT 2021
the profile manager is now available in QGIS flagged as experimental
Plugin. My colleague Dominik will also present it on the next QGIS Open
Day (2021-10-29)
with the following features:
  * Create a new profile
      o Creates and initiates a new QGIS profile
  * Removing profile
      o Removes the currently marked profile
  * Copy profile
      o Copies profile into a new one with a name provided by the user
  * Rename profile
      o Renames the profile with a name provided by the user
  * Importing Datasources from one profile to another (Datasources are
    chosen by checking them in a TreeView where each source is displayed)
  * Removing Datasources from a profile
      o Removes the datasources from the chosen SOURCE profile
  * Importing bookmarks
  * Importing favourites
  * Importing plugins
  * Importing functions
  * Importing models & scripts
  * Importing style & label settings
  * Importing QGIS UI settings (f.e. hidden toolbar items)
code: https://github.com/dszillWG/profile-manager
Am 06.10.2021 um 17:52 schrieb Raymond Nijssen:
> On 06-10-2021 17:26, Etienne Trimaille wrote:
>> Hi Raymond and others,
>> A plugin is very often the culprit, which is installed by the user :)
> Hi Etienne and others,
> QGIS itself is also installed by the user :)
> But it doesn't mean the user is to blame for bugs in it, or can be
> expected to fix them. Same counts for plugins.
> Maybe instead of making new profiles, we can have functions for fixing
> an existing profile?
> - Turn off all plugins
> - Remove all plugins
> - Remove all custom expressions
> - Remove startup script
> In a usual suspect kind of order?
> Maybe Stefan's Profile Manager will do it?
> Cheers,
> Raymond
> Qgis-user mailing list
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Schon gewusst?
In unserem Blog geben wir Tipps & Tricks zu
Open-Source-GIS-Software und berichten aus unserem Experten-Alltag:
https://wheregroup.com/blog/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211018/bcc076fc/attachment.html>
