[Qgis-user] symbology shapefile polygons: equal intervals classes
Charles Dixon-Paver
charles at kartoza.com
Tue Oct 19 05:51:57 PDT 2021
I'm not sure of a faster way to achieve this exactly, but if you use the
"pretty breaks" method and the appropriate number of classes you can get
quite close to the desired outcome, and maybe just remove the last class
created to round down the output. Pretty breaks will try to automatically
perform some serious rounding to get more human-friendly values than
natural breaks. Precision and trim options can help clean up the legend
results as well.
On Tue, 19 Oct 2021 at 14:28, Azzurra Lentini <azzurralentini at gmail.com>
wrote:
> Dear all,
> I have a shapefile of polygons and I would like to classify it (in
> symbology) using for example 6 classes with these values
> 0-10
> 10-20
> 20-30 etc.
> The field to classify has values from 0 to 63.4 (decimal numbers).
> And I would like to have the result in graduated colors.
> Till now I have been using:
> *Symbology*/graduated
> *Method* color and I give a color ramp
> *Mode: *equal interval and I give the number of classes,
> the problem is that I must insert the classes manually (one by one)
> otherwise the numbers are not entire.
> Please can you suggest me any other faster method? (for example for the
> raster I can give minimum and maximum as integer number -in this case it
> would be 0 - 60- and I can specify the number of classes and automatically
> Qgis tematize the raster with equal intervals (all the classes and not one
> by one).
> Thank you Azzurra
> Gis Expert for Environmental Science
> Environmental Disasters, Hydrogeology, Climate
> [image: image.png]
> *Eur**opean **Commission*
> *Joint Research Centre*
> Adjunct Professor University "Roma Tre"
> AZZURRA LENTINI
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *azzurralentini at gmail.com <azzurralentini at gmail.com>*
> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> *
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211019/635d68c1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211019/635d68c1/attachment-0001.png>
