[Qgis-user] When running a Custom Function, the return value is different from when stepping through it and watching the 'Preview' value in Field Calculator
Zoltan
zoltans at geograph.co.za
Tue Oct 19 09:32:50 PDT 2021
Me again :-(
I've written a custom function in Field Calculator and want to put its
return value into a new Text field in the attribute table.
When I step through the features I get the correct and expected values
shown next to 'Preview'
But
when I click OK to run the Field Calculator, it runs for a long enough
time, auto-closes on completion and in the attribute table the new field
is created, but value is 'Nothing for None' for all features.
*Note:* variable rd_at reflects correct contents when stepping through
and observing 'Preview' but seems to revert to Nonetype when running the
function.
What am I missing regarding using custom functions?
Is it an intended thing that the Field Calculator auto-closes after
running a custom function?
Thanks again,
Kind regards,
Zoltan
*Note:* The msg variable was introduced in case placing 'return' in
various lines in the script was causing problems. I have also made the
script below "more pedantic" to try and debug it.
from qgis.core import *
from qgis.gui import *
import processing
@qgsfunction(args='auto', group='Custom', referenced_columns=[])
def del_cutboxes(feature, parent):
geom = feature.geometry()
attr = feature.attributes()
rd_at = str(attr[5])
lyr_rcl =
QgsVectorLayer('Z:/Projects/RCL_boxes.shp','lyrrcl','ogr')
rcl_feats = lyr_rcl.getFeatures()
msg = ''
for rcl_feat in rcl_feats:
if len(msg) == 0:
rclbox = rcl_feat.geometry()
if rclbox.contains(geom):
if rcl_feat.attributes()[0] is not rd_at:
#feature.delete()
msg = 'ToDelete ' + rd_at
else:
msg = 'ToKeep ' + rd_at
if len(msg) == 0:
msg = 'Nothing for ' + rd_at
return msg
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211019/2230fc43/attachment.html>
