[Qgis-user] QAD Dimenssioning plugin
    Norman Trowell
    trowell.n at gmail.com
    Tue Oct 19 11:33:37 PDT 2021
Where would I download QAD manual?
*Norm Trowell*
*25 Lancaster Drive*
*Sudbury, Ontario*
*P3E 3R5*
*Phone:705-670-8281*
*Email:trowell.n at gmail.com <Email%3Atrowell.n at gmail.com>*
On Mon, Oct 18, 2021 at 3:50 AM <gam17 at riseup.net> wrote:
> Hi Miquel Pujol Garcia,
>    in the QAD manual you can read...
> Hope it helps.
> bye
> gam17
> Layer
> QAD supports all types of vector layers of QGIS with a distinction
> regarding the point layer. In fact, QAD manage layers of QGIS
> distinguishing between symbols layers and text layers. The first
> displays symbols while the second displays texts.
> The text layer is a layer that displays labels only. It is a QGIS point
> layer with the following characteristics:
> 1.      the symbol must have a minimum of 90% transparency
> 2.      must have a label
> Layers that are not textual will be considered as symbol layers.
> Text layer model:
> The text layer must have the following fields:
> •       a character field to store text
> Optional fields:
> •       a real number field to store the text height (map unit)
> •       a real number field to store text rotation (degree counterclockwise
> where zero = horizontal to the right)
> The textual layer must be defined with labels set as follows:
> •       the size can be read from a real number field that stores the text
> height (in map units, tab <Labels>-<Text>, if set than the TEXT command
> will ask for it)
> •       the rotation can be read from a real number field that stores text
> rotation (degree counterclockwise where zero = horizontal to the right),
> <Preserve data rotation values> option enabled (tab
> <Labels>-<Placement>, if set than the TEXT command will ask for it)
> Symbol layer model:
> The symbol layers may have the following optional fields:
> •       a real number field to store the symbol rotation (degree
> •       a real number field to store the symbol scale
> The symbol layer can be defined with a style set as follows:
> •       If you decide to handle the rotation or scale of symbols then the
> <Style>-<Single Symbol> option and <Style>-<map units> option must be
> enabled
> •       The rotation could be read by a real number field that stores the
> symbol rotation through the formula "360-<field that stores the
> rotation>" (degree counterclockwise where zero = horizontal to the
> right, <Style>-<Advanced> option "rotation field name"-<Espressione>, if
> set than the INSERT command will ask for it)
> •       The scale can be read by a real number field that stores the scale
> of
> the symbol (<Style>-<Advanced>-<Size scale field>-“ field that stores
> the scale” and <Style>-< Advanced >-<Size scale field >-<Scale
> diameter>, if set than the INSERT command will ask for it)
> > Hi Qgisers,
> > I'm using QAD Dimension Plugin.
> > The plugin demand create 3 entities.
> > dim_line --> kind of data = line
> > dim_sym_arr --> kind of data = point
> > dim_text --> kind of data = ??????
> > Does someone know what kind of entity has to be the text?
> > Thanks,
> > ------------------------------------------------------Miquel Pujol
> > Garcia
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211019/9a006d73/attachment.html>
