[Qgis-user] QAD Dimenssioning plugin
gam17 at riseup.net gam17 at riseup.net
Wed Oct 20 00:05:44 PDT 2021
Hi Norm,
   every QAD window has a button on the right-bottom corner. This button
has the caption "?" indicating the help function which opens the manual
in the right page.
Let me know if it doesn't work.
Anyway, if you use a windows based pc, go to the
C:\Users\<your
user>\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\qad\help
directory where you will find the documentation (english/italian version
only).
hope this helps
bye
gam17
> Where would I download QAD manual?
> Norm Trowell
> 25 Lancaster Drive
> Sudbury, Ontario
> P3E 3R5
> Phone:705-670-8281
> Email:trowell.n at gmail.com
> On Mon, Oct 18, 2021 at 3:50 AM <gam17 at riseup.net> wrote:
>> Hi Miquel Pujol Garcia,
>> in the QAD manual you can read...
>> Hope it helps.
>> bye
>> gam17
>> Layer
>> QAD supports all types of vector layers of QGIS with a distinction
>> regarding the point layer. In fact, QAD manage layers of QGIS
>> distinguishing between symbols layers and text layers. The first
>> displays symbols while the second displays texts.
>> The text layer is a layer that displays labels only. It is a QGIS
>> point
>> layer with the following characteristics:
>> 1.      the symbol must have a minimum of 90% transparency
>> 2.      must have a label
>> Layers that are not textual will be considered as symbol layers.
>> Text layer model:
>> The text layer must have the following fields:
>> •       a character field to store text
>> Optional fields:
>> •       a real number field to store the text height (map unit)
>> •       a real number field to store text rotation (degree
>> counterclockwise
>> where zero = horizontal to the right)
>> The textual layer must be defined with labels set as follows:
>> •       the size can be read from a real number field that stores
>> the text
>> height (in map units, tab <Labels>-<Text>, if set than the TEXT
>> command
>> will ask for it)
>> •       the rotation can be read from a real number field that
>> stores text
>> rotation (degree counterclockwise where zero = horizontal to the
>> right),
>> <Preserve data rotation values> option enabled (tab
>> <Labels>-<Placement>, if set than the TEXT command will ask for it)
>> Symbol layer model:
>> The symbol layers may have the following optional fields:
>> •       a real number field to store the symbol rotation (degree
>> counterclockwise where zero = horizontal to the right)
>> •       a real number field to store the symbol scale
>> The symbol layer can be defined with a style set as follows:
>> •       If you decide to handle the rotation or scale of symbols
>> then the
>> <Style>-<Single Symbol> option and <Style>-<map units> option must
>> be
>> enabled
>> •       The rotation could be read by a real number field that
>> stores the
>> symbol rotation through the formula "360-<field that stores the
>> rotation>" (degree counterclockwise where zero = horizontal to the
>> right, <Style>-<Advanced> option "rotation field
>> name"-<Espressione>, if
>> set than the INSERT command will ask for it)
>> •       The scale can be read by a real number field that stores
>> the scale of
>> the symbol (<Style>-<Advanced>-<Size scale field>-“ field that
>> stores
>> the scale” and <Style>-< Advanced >-<Size scale field >-<Scale
>> diameter>, if set than the INSERT command will ask for it)
>>> Hi Qgisers,
>>> I'm using QAD Dimension Plugin.
>>> The plugin demand create 3 entities.
>>> dim_line --> kind of data = line
>>> dim_sym_arr --> kind of data = point
>>> dim_text --> kind of data = ??????
>>> Does someone know what kind of entity has to be the text?
>>> Thanks,
>>> ------------------------------------------------------Miquel Pujol
>>> Garcia
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
