[Qgis-user] Crashing with snapping and WFS !?
Alessandro Pasotti
apasotti at gmail.com
Fri Oct 22 01:32:59 PDT 2021
this really sounds like a bug, can you file a ticket if there isn't one
already?
On Fri, Oct 22, 2021 at 4:16 AM Michael Dufty <
MDufty at mbsenvironmental.com.au> wrote:
> I'm not sure if its related, but I often have issues with snapping and
> arcgis rest layers. The problem is if snapping is enabled QGIS will index
> the entire layer. If it happens to be a national dataset - the sort of
> thing web layers are great for, this can take an hour or so, with QGIS
> unresponsive for the whole time often it won't actually crash if you are
> patient enough, but better to force quit if you have saved. Often I don't
> even want to snap to that layer, just accidentally had snap to all layers
> enabled, and once you realise it is happening it is too late to save the
> setting. Even worse the settings only seem to be available when snap is
> enabled, so to fix it, you need to hide the layer, turn snap on, change the
> settings, then turn the layers back on.
> Michael Dufty
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Lars I.
> Nielsen
> Sent: Wednesday, 20 October 2021 7:29 PM
> To: Julien Cabieces <julien.cabieces at oslandia.com>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Crashing with snapping and WFS !?
> Thanks Julien.
> It's on Windows. It's at a customer, so I'm not entirely sure what
> version, except that it's Windows 10.
> I did a bug report on it: # 45589.
> Cheers
> Lars
> -----Oprindelig meddelelse-----
> Fra: Julien Cabieces [mailto:julien.cabieces at oslandia.com]
> Sendt: 18. oktober 2021 09:15
> Til: Lars I. Nielsen
> Emne: Re: [Qgis-user] Crashing with snapping and WFS !?
> Hi,
> Could you please open an issue here https://github.com/qgis/QGIS/issues
> Does it happen on Linux or Windows ?
> Do you manage to reproduce the issue every time or it happen randomly?
> Kind regards,
> Julien
> > Hi list.
> > We’re running a dataset via WFS (Geoserver 2.16) into QGIS.
> > The user has snap turned on while digitizing/editing, and too often this
> combo results in QGIS crashing.
> > However, this crash does not happen when digitizing/editing, but during
> other operations like panning the map or something similar.
> > The stack dump mentions “snapPoint”, “snapToMap”, “nearestVertex”, and
> “closestVertex”, which to me implies the snapping function in action.
> > It also mentions “canvasMoveEvent”, which to me implies a panning
> operation.
> > I expect the snapping operation to be entirely local, i.e. independent
> of actual data source type, but this apparently only happens when using a
> WFS data source.
> > Can anyone shed some light on this unexpected behavior ? Is it a bug ?
> > Here’s the crash dialog box:
> > QGIS is version 3.16.10, as the stack dump shows.
> > Med venlig hilsen
> > Lars I. Nielsen
> > GIS-kons., FME+Python Certified Professional
> > GeoData
> > Dir. +4563136849
> > Tlf. +4563136800
> > Mail +lin at lifa.dk
> > LIFA A/S · Tlf +4563136800 · lifa.dk · CVRI20937289
> > Odense · København · Fredericia · Vejle · Kolding · Aarhus · Middelfart
> · Vissenbjerg · Kerteminde
> > * Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> Qgis-user mailing list
Alessandro Pasotti
QCooperative: www.qcooperative.net
ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211022/75922e19/attachment.html>
