[Qgis-user] GISBASE environment variable contains the wrong value
    Charles Dixon-Paver
    charles at kartoza.com
    Tue Sep  7 13:11:19 PDT 2021
I imagine a few things could be happening here. One way to test if the
"system" environment variable is set correctly is to use cmd to run echo
%GISBASE% and see where the default path is pointing to. If it is pointing
to the correct path then likely the variable is being overwritten by the
QGIS bootstrapping configuration. Have a look in the
C:\OSGeo4W\bin\qgis-bin.env or C:\OSGeo4W\bin\qgis-dev-bin.env files to see
if the references are correct. Otherwise maybe try a new user profile.
On Tue, 7 Sept 2021 at 19:15, Rick Rupp <palousegeo at outlook.com> wrote:
> I am using QGIS 3.20 on Windows 10. I installed QGIS using the new version
> of OSGeo4W. My installation is in a \OSGeo4W folder. When I try to execute
> a GRASS function, I get an error saying the program couldn’t find the
> function, but it is looking for it in a \OSGeo4W64 folder(default for the
> old version of OSGeo4W). I checked my Windows environment variables, and
> the GISBASE variable was pointing to the old location. I corrected this,
> rebooted, but QGIS still reports the old location on the System Options
> dialog. All the other OSGeo4W paths are correct. Is there another location
> from where the GISBASE variable is read?
> My work around is to just use GRASS for the needed functions, as the
> standalone program runs fine. Any suggestions are appreciated.
> Regards, Rick
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210907/aea90868/attachment.html>
