[Qgis-user] Convert LYR 2 SHP
Allan López
allosa01 at gmail.com
Tue Sep 7 17:04:32 PDT 2021
Awesome, thanks!
aLL the Best,
Allan
El mar, 7 de sep. de 2021 a la(s) 17:58, Nyall Dawson (
nyall.dawson at gmail.com) escribió:
> On Wed, 8 Sept 2021 at 05:58, Charles Dixon-Paver <charles at kartoza.com>
> wrote:
> > To my knowledge, lyr files are definitions for data sources, styles, and
> other layer configuration information.
> Correct. They are a direct equivalent of QLYR/QML files in QGIS land.
> > If you have a layer package you want to convert or extract data from,
> I'm not actually sure of what FOSS tooling supports it at all.
> A lpk is actually just a 7zip file renamed with a different extension.
> If you open the lpk in 7zip you'll see a .lyr file with the styling
> information together with a .gdb dataset containing the actual layer
> data. The .gdb will open fine in QGIS, but you'd need the licensed
> SLYR plugin in order to get the original .lyr styling to apply.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210907/64ee8153/attachment-0001.html>
