[Qgis-user] Multi User - QGIS
Alexander Klemm - km3 teledienst GmbH
alexander.klemm at km3.de
Sun Sep 12 23:27:35 PDT 2021
Hello,
we want to use QGIS to document our cable Infrastructure (We are an
ISP). Now the Problem is, that 3 or 4 persons have to work with QGIS.
Now my Idea was to provide a Postgresql Server with postgis installed.
Thats working fine. The Project and the Layers are stored into the
Postgresql Server and all Persons could work with it. Now my Problem is,
that the Contents of the Layers must have an unique ID. The ID is set by
the default value at the attribute form with/"maximum($id)+1"/. If two
persons are working on the QGIS System, the Problem is, that there are
duplicated IDs, because the IDs will not be stored immediately. Is there
a solution for this problem?
thank you for helping
best regards
Alexander Klemm
Mit freundlichen Grüßen
Alexander Klemm
km3 teledienst GmbH - August-Bebel-Str. 86 - 08344 Gruenhain-Beierfeld
Tel. +49 (0)3774 13931-0 - Fax +49 (0)3774 13931-02
buero at km3.de - https://www.km3.de
Geschaeftsfuehrer: Heiko Loetzsch und Mike Bielagk
Registergericht: Amtsgericht Chemnitz - Handelsregister: B Nr. 18881
Umsatzsteuer-ID: DE 216 086 551 - Steuer-Nr.: 218 / 112 / 02921
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210913/1a17683f/attachment.html>
