[Qgis-user] Point Shape file to Raster conversion.
Charles Dixon-Paver
charles at kartoza.com
Mon Sep 20 12:54:23 PDT 2021
You can use the *Project >> Import/Export >> Export Map to Image* and then
make sure you select the "*Append georeference information*" option. I have
set up a screenshot here: https://imgur.com/a/soAI4E5
If you still don't have any luck try making sure you are using a projected
CRS.
Regards
On Mon, 20 Sept 2021 at 21:45, krishna Ayyala <ayyalakrishna at gmail.com>
wrote:
> Charles,
> Thanks for your reply. By exporting it as a png, I am losing the
> georeferenced information.i.e. when I add this png to my map, it is not
> falling at the appropriate location. When you get a chance, can you please
> guide me, How do I export it to a raster such that I do not lose the
> georefereced information, at the same time it should look like similar to
> the vector file.
> Regards.
> On Mon, Sep 20, 2021 at 1:27 PM Charles Dixon-Paver <charles at kartoza.com>
> wrote:
>> You can export the map canvas as a png with a world file. If you want a
>> specific dimension or aspect ratio you can do the same with the layout
>> manager.
>> On Mon, 20 Sep 2021, 20:37 krishna Ayyala, <ayyalakrishna at gmail.com>
>> wrote:
>>> Hello,
>>> I have a point shape file. Is it possible to convert it to a raster such
>>> that the resultant file will also appear like points only. Similar to how
>>> it was looking like when it was a vector file.
>>> Regards.
>>> [image: image.png]
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210920/04afc762/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210920/04afc762/attachment.png>
