[Qgis-user] Point Shape file to Raster conversion.
krishna Ayyala
ayyalakrishna at gmail.com
Mon Sep 20 15:20:29 PDT 2021
Charles,
When you get a chance, can you please help me with one question? I have
created a geotiff file as per the direction in the link below. When I add
this geotiff file to google earth, I am getting all the points but a white
background. Is there a way to eliminate this white background?
https://imgur.com/a/soAI4E5
On Mon, Sep 20, 2021 at 1:54 PM Charles Dixon-Paver <charles at kartoza.com>
wrote:
> You can use the *Project >> Import/Export >> Export Map to Image* and
> then make sure you select the "*Append georeference information*" option.
> I have set up a screenshot here: https://imgur.com/a/soAI4E5
> If you still don't have any luck try making sure you are using a projected
> CRS.
> Regards
> On Mon, 20 Sept 2021 at 21:45, krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Charles,
>> Thanks for your reply. By exporting it as a png, I am losing the
>> georeferenced information.i.e. when I add this png to my map, it is not
>> falling at the appropriate location. When you get a chance, can you please
>> guide me, How do I export it to a raster such that I do not lose the
>> georefereced information, at the same time it should look like similar to
>> the vector file.
>> Regards.
>> On Mon, Sep 20, 2021 at 1:27 PM Charles Dixon-Paver <charles at kartoza.com>
>> wrote:
>>> You can export the map canvas as a png with a world file. If you want a
>>> specific dimension or aspect ratio you can do the same with the layout
>>> manager.
>>> On Mon, 20 Sep 2021, 20:37 krishna Ayyala, <ayyalakrishna at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I have a point shape file. Is it possible to convert it to a raster
>>>> such that the resultant file will also appear like points only. Similar to
>>>> how it was looking like when it was a vector file.
>>>> Regards.
>>>> [image: image.png]
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210920/e69c72b6/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210920/e69c72b6/attachment.png>
