[Qgis-user] batch operation on gpkg with multiple layers
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Sep 24 04:05:47 PDT 2021
Thanks,
I will check it out on Monday. Could be very useful.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 24 sept. 2021 à 02:47, Jésahel Benoist <djes1975 at gmail.com> a écrit :
> Hi Nicolas,
> I had similar questions and so I looked and found that it's easy to mix normal qgis (like loading all layers, using intensively the great browser panels to drag'n'drop), some tools (like the packaging tool) and some basic python with this simple loop :
> selectedLayers = iface.layerTreeView().selectedLayersRecursive()
> for layer in selectedLayers:
> layer.startEditing()
> ;Do your stuff here
> layer.triggerRepaint()
> I've created a basic plugin (https://github.com/djes/MultipleLayersTools) for my own needs, take a look at the code. If I have time I could add some of your needs.
> Btw, using geopackage is great for exchange and backup. But a real db server is a must have.
> Regards,
> Jésahel
>> Le jeu. 23 sept. 2021 à 22:33, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
>> Hi,
>> Before I go to my default mode and python my way through this, is there a plugin that would permit me to perform batch operation on all the layers found in a single .gpkg file? My geopackages contain hundreds of layers (from autocad) (contain identical data structures) and I would like to do things like:
>> Perform field calculator operations on each layer within the geopackage
>> Split all geopackage layer with a field
>> Merge multiple layers in a new geopackage
>> I guess FME would be another way out? I there an OpenSource equivilant to this? (I have a home version but I need to respect the license for this one.)
>> Nicolas
>> Nicolas Cadieux
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210924/5c9d7e72/attachment.html>
