[Qgis-user] Problem trying to graduate by value (colum)
Claudio Briones Barrera
cbriones at ull.edu.es
Wed Apr 6 04:38:57 PDT 2022
Thanks for the tip!
Claudio
<https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail>
Libre
de virus. www.avast.com
<#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
El mié, 6 abr 2022 a las 12:33, Nicolas Cadieux (<
njacadieux.gitlab at gmail.com>) escribió:
> Hi,
> Your number fields are probably using a text format. You cannot graduate
> a text field.
> Create a new field (columns) with a float or int and, using the field
> calculator to copy the data from the text field this new field. You can
> also just change the field type but if you do that, backup the data first
> as some data may be lost. Make sure the data is good before continuing as
> having a mixe of number format (like using commas and points) is all good
> for a text field but will not be appreciated by the number field. They
> will become NULL data.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 5 avr. 2022 à 07:25, Claudio Briones Barrera via Qgis-user <
> qgis-user at lists.osgeo.org> a écrit :
> Hello, my name is Claudio.
> Versión de QGIS
> 3.16.1-Hannover
> Problem: When I open Layer Properties of a Layer, and I try to edit Symbol
> by value (colum), I cant select any colum. If I try to do it in the
> categorized way, I do can select the colum without problem. Why?
> Thank you for your attention,
> Regards
> Profesor del Área de Mecánica de Medios Continuos y Teoría de las
> Estructuras
> Departamento de Técnicas y Proyectos en Ingeniería y Arquitectura
> Avda. Ángel Guimerá Jorge, s/n. Escuela Politécnica Superior de Ingeniería
> Apartado 456
> 38200 La Laguna. S/C de Tenerife
> Teléfono: 922 31 98 93
> Email: c <egonza at ull.edu.es>briones at ull.edu.es
> ull.es <https://www.ull.es/>
> *Aviso de confidencialidad*
> Este mensaje puede contener información confidencial o legalmente
> protegida. El acceso a su contenido por personas distintas a las
> destinatarias no está autorizado. Por otro lado, el tratamiento
> desautorizado de datos de carácter personal puede suponer una infracción de
> la normativa vigente en Protección de Datos.
> Si usted ha recibido este mensaje por error, le informamos que la
> utilización, divulgación o reproducción de su contenido sin autorización
> está prohibida en virtud de la legislación vigente. En tal caso deberá
> comunicarlo al remitente y proceder de manera inmediata a su destrucción, así
> como la de cualquier documento adjunto al mismo.
> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Libre
> <#m_5960106328338308417_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> Qgis-user mailing list
Estructuras
Apartado 456
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220406/fc692d36/attachment-0001.html>
