[Qgis-user] Issue " GDAL chokes opening attached JPG, yet works OK in other applications #1545 "
Andrea Giudiceandrea
andreaerdna at libero.it
Sun Apr 17 13:11:05 PDT 2022
> *Patrick Dunford*enzedrailmaps at gmail.com
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Issue%20%22%20GDAL%20chokes%20opening%20attached%20JPG%2C%0A%20yet%20works%20OK%20in%20other%20applications%20%231545%20%22&In-Reply-To=%3Cb2aa76f3-81c3-6b86-2530-8fc1cf38a92f%40gmail.com%3E>
> /Sun Apr 17 07:43:57 PDT 2022/
> The error message is spurious as the issue is found to be caused by
> using a Progressive JPEG as exported from Gimp. When the Progressive
> setting is turned off in the Gimp export settings there are no problems
> importing the raster in Qgis or displaying it.
Hi Patrick,
it would be useful if you could provide a sample image an attach it to
the issue report in order to debug your issue.
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220417/ab7d37ec/attachment.html>
