[Qgis-user] Activating ESRI geodatabase (.gdb) write mode in QGIS, OGR2OGR or Python
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Thu Apr 21 09:08:00 PDT 2022
Thanks for the tip, yesterday, all I had was read but for some reason, I
can now write so it works perfectly!  Looks like the problem was sitting
18 inches in front of the screen!
Cheers and thanks for your help!
Nicolas
On 2022-04-20 11:20 p.m., Saulteau Don via Qgis-user wrote:
> I think in the osgeo4w installer you just have to install the
> gdal-filegdb package for that driver.
> Donovan
> On Wed., Apr. 20, 2022, 18:11 Nicolas Cadieux via Qgis-user,
> <qgis-user at lists.osgeo.org> wrote:
>     Hi,
>     I am in a bit of a bind.  I am basically trying to figure out a
>     way to
>     write some .shp file to a .gbd folder using the gbd drivers obtained
>     from ESRI. I am not sure what file to copy and where.  I am tying to
>     make this work with ogr2ogr at the dos command prompt but getting to
>     work with a anaconda python environment would be nice.
>     Can the ESRI File Geodatabase API also be used write to a .gdb file
>     using QGIS?
>     If you recently did this, I would appreciate some tips.
>     I am on windows 10 using the OSGEO4W install with QGIS 3.24.
>     https://gdal.org/drivers/vector/filegdb.html
>     Thanks
>     Nicolas Cadieux
>     https://gitlab.com/njacadieux
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/48ea8522/attachment-0001.html>
