[Qgis-user] Activating ESRI geodatabase (.gdb) write mode in QGIS, OGR2OGR or Python
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Thu Apr 21 10:00:20 PDT 2022
Does anybody know how "Aliases" are saved in this type of data base?  If
I import files from a dataset, it has aliases for each layer but they
are not exported if I create a new "database". Perhaps this feature is
not fully supported yet as aliases are normally save in the QGIS project
file?
Thanks for the tips!
Nicolas
On 2022-04-21 9:42 a.m., Mike Treglia via Qgis-user wrote:
> That's correct in my experience. In the OSGeo4W installer, go through
> the advanced install menu, and when you get the options for libraries,
> I think searching for gdb should bring up the right one - then check
> the box and proceed.
> On Wed, Apr 20, 2022 at 11:22 PM Saulteau Don via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
>     I think in the osgeo4w installer you just have to install the
>     gdal-filegdb package for that driver.
>     Donovan
>     On Wed., Apr. 20, 2022, 18:11 Nicolas Cadieux via Qgis-user,
>         Hi,
>         I am in a bit of a bind.  I am basically trying to figure out
>         a way to
>         write some .shp file to a .gbd folder using the gbd drivers
>         obtained
>         from ESRI. I am not sure what file to copy and where.  I am
>         tying to
>         make this work with ogr2ogr at the dos command prompt but
>         getting to
>         work with a anaconda python environment would be nice.
>         Can the ESRI File Geodatabase API also be used write to a .gdb
>         file
>         using QGIS?
>         If you recently did this, I would appreciate some tips.
>         I am on windows 10 using the OSGEO4W install with QGIS 3.24.
>         https://gdal.org/drivers/vector/filegdb.html
>         Thanks
>         Nicolas Cadieux
>         https://gitlab.com/njacadieux
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220421/5285a349/attachment.html>
