[Qgis-user] QGIS 3.24 Ubuntu
Piet
plist at posteo.eu
Thu Apr 21 14:06:10 PDT 2022
Hello Angeles,
For your second question: Maybe you can compile an older version of Qgis by using Github
https://github.com/qgis/QGIS
How to uninstall Qgis is depending on the way you use to install it before, I guess.
But it would be possible to use different versions of Qgis as well (Keep your actual version
and compile Qgis in a separate folder).
Kind regards
Piet
Am 04/21/ schrieb Angeles Raphaël Saul via Qgis-user:
> Dear QGIS community,
> I have two questions : Do you know how to install easily pcraster on
> ubuntu ? How can I uninstall the latest version of QGIS 3.24 and get an
> older version of QGIS on ubuntu ?
> Situation : I am a recent ubuntu user and I need to install pcraster for
> advanced watershed calculations. Apparently it is possible to install
> it using anaconda-navigator, so I first needed to install anaconda using
> this tutorial
> : [1]https://gisunchained.wordpress.com/2019/05/29/using-qgis-from-conda/.
> But once QGIS 3.18.3 installed and opened, any plugin utilization do not
> work at all. For example, applying strahler order tool from SAGA on a DEM
> does not work. Every time, the python error is :
> WARNING Traceback (most recent call last):
> File
> "/home/raphael/anaconda3/envs/demonstration/share/qgis/python/plugins/processing/gui/AlgorithmDialog.py",
> line 194, in runAlgorithm
> self.cancelButton().setEnabled(self.algorithm().flags() &
> QgsProcessingAlgorithm.FlagCanCancel)
> TypeError: setEnabled(self, bool): argument 1 has unexpected type
> 'Flags'
> Thus I tried to install QGIS 3.24 via this
> link [2]https://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu to
> see if the problem can be resolved with a more recent version. The problem
> is that this tutorial is not for a conda environment, so now I want to
> uninstall 3.24 to go to an older and more stable version and I don't know
> how to do it. If I install and uninstall QGIS, the version 3.24 still
> appears. Moreover, I still don't have pcraster installed and operational
> which I need the most.
> Thank you in advance for your precious answer and have a good night!
> Raphaël
> References
> Visible links
> 1. https://gisunchained.wordpress.com/2019/05/29/using-qgis-from-conda/
> 2. https://www.qgis.org/en/site/forusers/alldownloads.html#debian-ubuntu
> Qgis-user mailing list
Kind regards
Piet
GPG Fingerprint: 1D9D DAD5 BD91 A5E8 C5DB B400 D286 3A10 4969 7909
