[Qgis-user] QGIS Server install
Nicolas Boisteault nboisteault at 3liz.com
Fri Apr 22 06:23:11 PDT 2022
I suggest you to try Docker with docker-composer.
Here is an example :
https://github.com/3liz/lizmap-docker-compose/blob/master/docker-compose.yml
Le 21/04/2022 à 02:26, Silvia Vitorino Pereira via Qgis-user a écrit :
> Hi everybody,
> I'm completely new with QGis Server.
> To install it on my Win10 Pro, I followed the steps in
> <https://docs.qgis.org/testing/en/docs/server_manual/getting_started.html#installation-on-windows>,
> paing attention to install the same desktop and server versions (QGIS
> 3.22-6). But when I try to run the server I get the follwing message:
> "The curl_multi_poll procedure entry point could not be located in the
> dynamic link library C:\OSGeo4W\bin\gdal304.dll" (something like that).
> To call the server, I used
> <http://localhost/cgi-bin/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities>
> Someone could help me with this?
> Thank you in advance,
> *Silvia V. Pereira*
> LABREN - Laboratório de Modelagem e Estudos de Recursos Renováveis de Energia
> DIIAV - Divisão de Impactos, Adaptação e Vulnerabilidades
> INPE - Instituto Nacional de Pesquisas Espaciais
> Av. dos Astronautas, 1758 - Jd. Granja
> São José dos Campos - SP - Brasil
> CEP 12227-010
> Tel.: +55 12 3208-7908
> ___________________________________
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220422/c6eeeaa6/attachment.html>
