[Qgis-user] Wrong area count QGIS 3.20+?
    Sebastian Gutwein
    bas at rdgland.com
    Mon Jan  3 06:46:47 PST 2022
Ok to add to the fun I tried the calculations in ArcPro and interestingly
if I run it using calculate field with this expression
*!shape.geodesicArea at hectares!* I get the QGIS 3.22 value of 31271112 but
if I run Geoprossessing Add Geometry Attributes I get the QGIS 3.16 value
of 31271108.
[image: image.png]
So if you want them to match I guess you should use the python expression
in ArcGIS Pro!
I guess we are back to the old adage of All Measuring is Guessing.
-Bas
On Mon, Jan 3, 2022 at 8:43 AM Sebastian Gutwein <bas at rdgland.com> wrote:
> Yes that was my read as well except previously it was the Grass method and
> now it is Geographic Lib method because that is theoretically more accurate
> and is the same method that is used in Postgis and other places. The
> switched happened because someone noticed the difference between QGIS’s
> calculations and Postgis’s calculations. If I am reading the pull requests
> correctly even Grass has switched to the Geographic Lib method. I’m
> surprised that ArcGIS Pro uses the same method as the Grass method.
> On Mon, Jan 3, 2022 at 2:57 AM Sadowski Jarosław <jaroslaw.sadowski at cpk.pl>
> wrote:
>> Sebastian,
>> thank you very much for your precise answer and materials sent - I have
>> read them carefully.
>> So, as far as I can understand, QGIS has moved in version 3.20 to a new
>> way of counting areas (other libraries? GRASS algorithm instead of
>> Geographic lib? I have actually noticed a different nomenclature and
>> definition of EPSG 2180 for some time in new versions…), that will be more
>> accurate?
>> I must admit that, for me as a GIS operator, it is surprising and sounds
>> like bad news - so far surfaces have always been the same in various GIS
>> software, whether or not it was open-source or commercial (ArcGIS Pro). So
>> from this moment it will be that I will get different surfaces depending on
>> the software it was calculated? :(
>> with kind regards
>> JS
>> *_____________________________*
>> *Jarosław Sadowski*
>> Ekspert ds. Baz Danych i Analiz Przestrzennych | *Biuro Strategii i
>> Planowania, Projektowania i Inżynierii Podprogramu Kolejowego*
>> *Database and Spatial Analysis Expert |Railway Subprogramme Strategy &
>> Planning, Design & Engineering Department*
>> e: jaroslaw.sadowski at cpk.pl
>> *From:* Sebastian Gutwein <bas at rdgland.com>
>> *Sent:* Saturday, January 1, 2022 7:13 AM
>> *To:* Sadowski Jarosław <jaroslaw.sadowski at cpk.pl>
>> *Cc:* qgis-user at lists.osgeo.org
>> *Subject:* Re: [Qgis-user] Wrong area count QGIS 3.20+?
>> Nie otrzymujesz często wiadomości e-mail z adresu bas at rdgland.com. Dowiedz
>> się, dlaczego jest to ważne
>> <http://aka.ms/LearnAboutSenderIdentification>
>> There was some discussion on this in the list serve back in January
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2F2021-January%2F047638.html&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bUHOuswrG6tPdkebzFYem%2BVsSrgjFhbSLVcKCiu6TW0%3D&reserved=0>
>> that resulted in this feature request
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fissues%2F40888&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dY89NsDscjybmwQPMV9PjPOwckPlcv%2B8TEWjl69rTtM%3D&reserved=0>
>> and this pull request
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fpull%2F41726&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IRMFsaJYT7xpylDJCZNvXAUNzdmtTjNbI4VyQMKtedE%3D&reserved=0>.
>> I tested your polygon, to the best of my limited ability, and the areas
>> were indeed different in QGIS 3.16 and 3.22 as would be expected from that
>> change . However it would be hoped that the area measurement would be more
>> accurate in 3.22.
>> On Fri, Dec 31, 2021 at 6:49 AM Sadowski Jarosław <
>> jaroslaw.sadowski at cpk.pl> wrote:
>> Dear all,
>> I am asking for help with QGIS error/bug or verification of proper usage
>> of basic QGIS functionality “$area”.
>> From version 3.20 upwards, it counts areas differently than before (3.18
>> calculated area is different than 3.20). Up to version 3.18 everything was
>> fine, equal to calculations from ArcGIS Pro (geodesic mode).
>> Anyone have an idea where the differences come from?
>> This is example vector [image: Ikona zip] PL_2180.zip
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcpkonline-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fjaroslaw_sadowski_cpk_pl%2FEVs0-TiEvPdBjMaqXrEvGfoBI0VussbJaYHdDVFfQnEYug%3Fe%3DVDY3rf-&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=JlPtyjeeYHQxV0DdlGrsPwjTNy9FHqqyEqEpLNrian8%3D&reserved=0>:
>> Polish borders in EPSG: 2180, in the table of attributes you can see the
>> areas (hectares) calculated for different versions of the software.
>> with wishes for more success in the new year
>> Jarosław Sadowski
>> *_________________________________*
>> *Jarosław Sadowski*
>> *Database and Spatial Analysis Expert | Railway Subprogramme Strategy &
>> m: +48 532 720 230
>> Centralny Port Komunikacyjny Sp. z o.o. z siedzibą w Warszawie, Aleje
>> Jerozolimskie 142B, 02-305 Warszawa; nr KRS 0000759991, Sąd Rejonowy dla
>> m.st
>> <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fm.st%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oT4ox6NtPJ4TlAS2CTPM0KgLWAFOMUZ2O1N9EEE4Dfc%3D&reserved=0>.
>> Warszawy, XII Wydział Gospodarczy Krajowego Rejestru Sądowego; NIP
>> 701-08-94-497; REGON 381918620; kapitał zakładowy 1.277.500.000,00 zł
>> Administratorem danych osobowych przekazanych przez Panią/Pana m.in. w
>> korespondencji mailowej jest Centralny Port Komunikacyjny Sp. z o.o. z
>> siedzibą w Warszawie. Przetwarzamy dane osobowe zgodnie z przepisami
>> ogólnego rozporządzenia o ochronie danych (RODO), więcej informacji na ten
>> temat znajduje się w zakładce Polityka Prywatności oraz w Klauzuli
>> informacyjnej na stronie internetowej www.cpk.pl
>> <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3nB3VJa54%2FlK17eCUR2bvwIusD0MYzQQ1MmbCmbh3Is%3D&reserved=0>
>> Treści zawarte w niniejszej wiadomości i załącznikach do niej stanowią
>> Tajemnicę Przedsiębiorstwa w rozumieniu ustawy z dnia 16 kwietnia 1993 r. o
>> zwalczaniu nieuczciwej konkurencji. Jeśli otrzymałeś tę wiadomość przez
>> pomyłkę, bezzwłocznie skontaktuj się z nadawcą wiadomości oraz usuń jej
>> treść.
>> Solidarity Transport Hub Poland: Centralny Port Komunikacyjny Sp. z o.o.
>> with headquarters in Warsaw, Aleje Jerozolimskie 142B, 02-305 Warsaw
>> <https://www.google.com/maps/search/Warsaw,+Aleje+Jerozolimskie+142B,+02-305+Warsaw?entry=gmail&source=g>;
>> KRS No. 0000759991, District Court for the Capital City of Warsaw, 12th
>> Commercial Department of the National Court Register; NIP 701-08-94-497;
>> REGON 381918620; share capital of PLN 1.277.500.000,00.
>> The personal data controller of the personal data provided by you, among
>> others, in the e-mail correspondence, is Centralny Port Komunikacyjny Sp. z
>> o. o. based in Warsaw. The personal data is processed by us in accordance
>> with the provisions of the General Data Protection Regulation (GDPR), for
>> further information please read the Privacy Policy tab and the Information
>> Clause on the www.cpk.pl
>> website.
>> The content of this message and its attachments constitute the Business
>> Secret within the meaning of the Act of 16 April 1993 on combating unfair
>> competition. If you received this message by mistake, contact the sender of
>> the message immediately and delete its content
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oFJ%2FkA4lI5PPgPaEOLyh3jG3Cp49JqK0FQ7eTYd%2FOjM%3D&reserved=0>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Sent from a phone. Amazing! But possibly garbled. Sebastian Gutwein
> Regenerative Design Group 1 Chevalier Ave Greenfield MA Bas at rdgland.com
> (631) 241-1018
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/1af7da98/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/1af7da98/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/1af7da98/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/1af7da98/attachment-0005.png>
