[Qgis-user] Wrong area count QGIS 3.20+?
Zoltan zoltans at geograph.co.za
Mon Jan 3 06:51:38 PST 2022
Hi Bas,
Please say which version of ArcPro - I might be heading for these type
of issues in the next few months.
Thanks and regards,
Zoltan
On 2022-01-03 16:46, Sebastian Gutwein wrote:
> Ok to add to the fun I tried the calculations in ArcPro and
> interestingly if I run it using calculate field with this expression
> *!shape.geodesicArea at hectares!* I get the QGIS 3.22 value of 31271112
> but if I run Geoprossessing Add Geometry Attributes I get the QGIS
> 3.16 value of 31271108.
> So if you want them to match I guess you should use the python
> expression in ArcGIS Pro!
> I guess we are back to the old adage of All Measuring is Guessing.
> -Bas
> On Mon, Jan 3, 2022 at 8:43 AM Sebastian Gutwein <bas at rdgland.com> wrote:
>     Yes that was my read as well except previously it was the Grass
>     method and now it is Geographic Lib method because that is
>     theoretically more accurate and is the same method that is used in
>     Postgis and other places. The switched happened because someone
>     noticed the difference between QGIS’s calculations and Postgis’s
>     calculations. If I am reading the pull requests correctly even
>     Grass has switched to the Geographic Lib method. I’m surprised
>     that ArcGIS Pro uses the same method as the Grass method.
>     On Mon, Jan 3, 2022 at 2:57 AM Sadowski Jarosław
>     <jaroslaw.sadowski at cpk.pl> wrote:
>         Sebastian,
>         thank you very much for your precise answer and materials sent
>         - I have read them carefully.
>         So, as far as I can understand, QGIS has moved in version 3.20
>         to a new way of counting areas (other libraries? GRASS
>         algorithm instead of Geographic lib? I have actually noticed a
>         different nomenclature and definition of EPSG 2180 for some
>         time in new versions…), that will be more accurate?
>         I must admit that, for me as a GIS operator, it is surprising
>         and sounds like bad news - so far surfaces have always been
>         the same in various GIS software, whether or not it was
>         open-source or commercial (ArcGIS Pro). So from this moment it
>         will be that I will get different surfaces depending on the
>         software it was calculated? :(
>         with kind regards
>         JS
>         *_____________________________*
>         *Jarosław Sadowski*
>         Ekspert ds. Baz Danych i Analiz Przestrzennych | /Biuro
>         Strategii i Planowania, Projektowania i Inżynierii Podprogramu
>         Kolejowego/
>         /Database and Spatial Analysis Expert |Railway Subprogramme
>         Strategy & Planning, Design & Engineering Department/
>         e: jaroslaw.sadowski at cpk.pl
>         *From:* Sebastian Gutwein <bas at rdgland.com>
>         *Sent:* Saturday, January 1, 2022 7:13 AM
>         *To:* Sadowski Jarosław <jaroslaw.sadowski at cpk.pl>
>         *Cc:* qgis-user at lists.osgeo.org
>         *Subject:* Re: [Qgis-user] Wrong area count QGIS 3.20+?
>         Nie otrzymujesz często wiadomości e-mail z adresu
>         bas at rdgland.com. Dowiedz się, dlaczego jest to ważne
>         <http://aka.ms/LearnAboutSenderIdentification>
>         There was some discussion on this in the list serve back in
>         January
>         <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fpipermail%2Fqgis-user%2F2021-January%2F047638.html&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=bUHOuswrG6tPdkebzFYem%2BVsSrgjFhbSLVcKCiu6TW0%3D&reserved=0>
>         that resulted in this feature request
>         <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fissues%2F40888&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=dY89NsDscjybmwQPMV9PjPOwckPlcv%2B8TEWjl69rTtM%3D&reserved=0>
>         and this pull request
>         <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fqgis%2FQGIS%2Fpull%2F41726&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=IRMFsaJYT7xpylDJCZNvXAUNzdmtTjNbI4VyQMKtedE%3D&reserved=0>.
>         I tested your polygon, to the best of my limited ability, and
>         the areas were indeed different in QGIS 3.16 and 3.22 as would
>         be expected from that change . However it would be hoped that
>         the area measurement would be more accurate in 3.22.
>         On Fri, Dec 31, 2021 at 6:49 AM Sadowski Jarosław
>             Dear all,
>             I am asking for help with QGIS error/bug or verification
>             of proper usage of basic QGIS functionality “$area”.
>             From version 3.20 upwards, it counts areas differently
>             than before (3.18 calculated area is different than 3.20).
>             Up to version 3.18 everything was fine, equal to
>             calculations from ArcGIS Pro (geodesic mode).
>             Anyone have an idea where the differences come from?
>             This is example vector Ikona zip PL_2180.zip
>             <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcpkonline-my.sharepoint.com%2F%3Au%3A%2Fg%2Fpersonal%2Fjaroslaw_sadowski_cpk_pl%2FEVs0-TiEvPdBjMaqXrEvGfoBI0VussbJaYHdDVFfQnEYug%3Fe%3DVDY3rf-&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=JlPtyjeeYHQxV0DdlGrsPwjTNy9FHqqyEqEpLNrian8%3D&reserved=0>:
>             Polish borders in EPSG: 2180, in the table of attributes
>             you can see the areas (hectares) calculated for different
>             versions of the software.
>             with wishes for more success in the new year
>             Jarosław Sadowski
>             *_________________________________*
>             *Jarosław Sadowski*
>             Podprogramu Kolejowego/
>             /Database and Spatial Analysis Expert | Railway
>             Subprogramme Strategy & Planning, Design & Engineering
>             Department/
>             e: jaroslaw.sadowski at cpk.pl <mailto:jaroslaw.sadowski at cpk.pl>
>             m: +48 532 720 230
>             Centralny Port Komunikacyjny Sp. z o.o. z siedzibą w
>             Warszawie, Aleje Jerozolimskie 142B, 02-305 Warszawa; nr
>             KRS 0000759991, Sąd Rejonowy dla m.st
>             <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fm.st%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oT4ox6NtPJ4TlAS2CTPM0KgLWAFOMUZ2O1N9EEE4Dfc%3D&reserved=0>.
>             Warszawy, XII Wydział Gospodarczy Krajowego Rejestru
>             Sądowego; NIP 701-08-94-497; REGON 381918620; kapitał
>             zakładowy 1.277.500.000,00 zł
>             Administratorem danych osobowych przekazanych przez
>             Panią/Pana m.in. w korespondencji mailowej jest Centralny
>             Port Komunikacyjny Sp. z o.o. z siedzibą w Warszawie.
>             Przetwarzamy dane osobowe zgodnie z przepisami ogólnego
>             rozporządzenia o ochronie danych (RODO), więcej informacji
>             na ten temat znajduje się w zakładce Polityka Prywatności
>             oraz w Klauzuli informacyjnej na stronie internetowej
>             www.cpk.pl
>             <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3nB3VJa54%2FlK17eCUR2bvwIusD0MYzQQ1MmbCmbh3Is%3D&reserved=0>.
>             Treści zawarte w niniejszej wiadomości i załącznikach do
>             niej stanowią Tajemnicę Przedsiębiorstwa w rozumieniu
>             ustawy z dnia 16 kwietnia 1993 r. o zwalczaniu nieuczciwej
>             konkurencji. Jeśli otrzymałeś tę wiadomość przez pomyłkę,
>             bezzwłocznie skontaktuj się z nadawcą wiadomości oraz usuń
>             jej treść.
>             Solidarity Transport Hub Poland: Centralny Port
>             Komunikacyjny Sp. z o.o. with headquarters in Warsaw,
>             Aleje Jerozolimskie 142B, 02-305 Warsaw
>             <https://www.google.com/maps/search/Warsaw,+Aleje+Jerozolimskie+142B,+02-305+Warsaw?entry=gmail&source=g>;
>             KRS No. 0000759991, District Court for the Capital City of
>             Warsaw, 12th Commercial Department of the National Court
>             Register; NIP 701-08-94-497; REGON 381918620; share
>             capital of PLN 1.277.500.000,00.
>             The personal data controller of the personal data provided
>             by you, among others, in the e-mail correspondence, is
>             Centralny Port Komunikacyjny Sp. z o. o. based in Warsaw.
>             The personal data is processed by us in accordance with
>             the provisions of the General Data Protection Regulation
>             (GDPR), for further information please read the Privacy
>             Policy tab and the Information Clause on the www.cpk.pl
>             <https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cpk.pl%2F&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=3nB3VJa54%2FlK17eCUR2bvwIusD0MYzQQ1MmbCmbh3Is%3D&reserved=0>website.
>             The content of this message and its attachments constitute
>             the Business Secret within the meaning of the Act of 16
>             April 1993 on combating unfair competition. If you
>             received this message by mistake, contact the sender of
>             the message immediately and delete its content
>             _______________________________________________
>             Qgis-user mailing list
>             Qgis-user at lists.osgeo.org
>             List info:
>             https://lists.osgeo.org/mailman/listinfo/qgis-user
>             <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7Cjaroslaw.sadowski%40cpk.pl%7Cf7cc24b07b7c42e8902a08d9ccedca61%7Cfa798250ca0b4a1bb47381cff4a1752b%7C1%7C0%7C637766145287655707%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=oFJ%2FkA4lI5PPgPaEOLyh3jG3Cp49JqK0FQ7eTYd%2FOjM%3D&reserved=0>
>             Unsubscribe:
>     Sent from a phone. Amazing! But possibly garbled. Sebastian
>     Gutwein Regenerative Design Group 1 Chevalier Ave Greenfield MA
>     Bas at rdgland.com (631) 241-1018
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/9b7792d0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/9b7792d0/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/9b7792d0/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220103/9b7792d0/attachment-0005.png>
