[Qgis-user] HTML Image Map
Richard Duivenvoorde
rdmailings at duif.net
Thu Jan 6 23:42:00 PST 2022
Hi Nev,
I'm the original author of the HtmlImageMap plugin (my earliest/first one, oct 2010): https://plugins.qgis.org/plugins/imagemap_plugin/
Students of Stefan (in bcc) created a version with more advanced html and javascript:
https://plugins.qgis.org/plugins/html-image-map-creator/
Both are indeed only available for QGIS 2.x
Are you sure you still want an ImageMap? I would say that for example saving your map to geojson and then use some simple Leaflet code would be more 2022 :-)
Would that be possible? Or or there still a group of users which are avid html-image map believers?
Because it would be a waste of time (to me) to port the old 2.x plugin to 3.x if nobody actually would use it...
@stefan: do you still have use for your version?
Regards,
On 1/7/22 06:09, nwastra nwastra wrote:
> Hi
> I have a .gdb file with catchment boundaries of river regions and would like to create a html image map with the name of the catchment displaying on hovering over each catchment and on selection giving a link to a file of that waterway data to download.
> I am using QGIS 3.22.2 and I can’t find a way to create a HTML imagemap.
> I found HTML Image Map Creator QGIS-Plugin <https://github.com/geometalab/HTML-Image-Map-Creator-QGIS-Plugin> but Qgis gave an error message *This plugin is incompatible with this version of QGIS *Plugin designed for QGIS 2.14.16 - 2.99
> Can QGIS 3.22 create an html image map or should I install 2.14 or is there another method?
> Nev
> Qgis-user mailing list
