[Qgis-user] QGIS Model Designer
Richard McDonnell richard.mcdonnell at opw.ie
Wed Jan 12 08:35:24 PST 2022
Apologies,
I meant I have very little experience working with Python…something I am constantly saying I need to remedy!
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Sent: 12 January 2022 16:31
To: Richard McDonnell <richard.mcdonnell at opw.ie>; Qgis Users List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] QGIS Model Designer
HI,
Python is installed with QGIS.  The easiest way is to go to plugins -> Python console.
Nicolas
On 2022-01-12 5:37 a.m., Richard McDonnell wrote:
Thanks for getting back. I am afraid I have no Python, but I will give it a go!!
Regards & Thanks
Richard.
FRM Data Management
https://gov.ie/opw
From: Ujaval Gandhi <ujaval at spatialthoughts.com><mailto:ujaval at spatialthoughts.com>
Sent: 11 January 2022 14:22
To: Richard McDonnell <richard.mcdonnell at opw.ie><mailto:richard.mcdonnell at opw.ie>
Cc: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
The batch processing and modeler are mising the 'iterate' feature, and this type of batch processing + merge functionality will be useful. I have a tutorial on how to write a bit of pyqgis code to do this that shows exactly the use case you have. But it can be used with any other processing algorithm. https://www.qgistutorials.com/en/docs/3/processing_algorithms_pyqgis.html
[Image removed                                                      by sender. Logo]<https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com<mailto:ujaval at spatialthoughts.com>
[Image                                                            removed by                                                            sender.                                                            LinkedIn icon]<https://www.linkedin.com/in/spatialthoughts/>  [Image                                                            removed by                                                            sender.                                                            Twitter icon] <https://twitter.com/spatialthoughts>
On Mon, Jan 10, 2022 at 4:52 PM Richard McDonnell <richard.mcdonnell at opw.ie<mailto:richard.mcdonnell at opw.ie>> wrote:
Hi All,
Apologies, but I think I have found a Plugin, which looks promising “Point sampling tool” which seems to do what I want.
Regards,
Richard
FRM Data Management
https://gov.ie/opw
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Richard McDonnell
Sent: 10 January 2022 11:18
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] QGIS Model Designer
Hi all.
I have been asked to sample over 100 raster pixel values using a single point file.
I can use the “Sample raster values” Tool, but this only outputs for one Raster. I have looked at batching this, but it will produce 100’s of point files which I will have to merge together. So I was looking at using the Model Designer, but again it can’t accept multiple raster inputs.
What I would like to know, is how I might easily create a single shapefile with a column for each raster containing the sampled value. The easiest way would be to somehow sample the first raster saving the output then loop back to the second raster, but this time using output from the first sampling to sample the second. This looping would continue until all raster’s had been sampled.
Any help appreciated.
Regards,
Richard
FRM Data Management
https://gov.ie/opw
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220112/be69e38f/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220112/be69e38f/attachment.jpg>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220112/be69e38f/attachment-0001.jpg>
