[Qgis-user] Lagging qgis
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Jan 19 13:15:18 PST 2022
Also, try a simple project with only the layer you are editing. If you have
too many layers and snapping enabled on all labels... It can be slow.
Alexandre Neto
User support
www.qcooperative.net
A quarta, 19/01/2022, 19:50, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> On 1/19/22 20:38, Alexandru Munteanu wrote:
> > Hi all,
> > I'm having a really hard time editing shapes in qgis, any kind of shapes
> (lines, polygons, dots). And doesn't matter the size of the shape file, I
> can have few points or lines in the layer.
> > The lagging varies from drawing something new, or moving vertices
> around. Even changing styles is difficult.
> > For example, I want to change the color of a line, or its width, so i
> select it's style, double click, wait a while for it to open, select the
> width, wait for to get selected, then wait a little for it to apply and so
> on.
> > What can be the problem? Anyone encountered something similar?
> Sometimes plugins are the culprit.
> Can you try to create a profile without any plugins in it and then see if
> it it still slow?
> If there is no problem anymore without plugins, you have to find the one
> that is creating the issue by enabling your old plugins one by one.
> HTH,
> Regards,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220119/610b5a5a/attachment.html>
