[Qgis-user] Update Null Geometry
    DelazJ
    delazj at gmail.com
    Thu Jan 20 08:11:01 PST 2022
Hi Hugh,
Use the "Add part" tool:
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#add-part
Regards,
Harrissou
Le jeu. 20 janv. 2022 à 17:02, Hugh Kelley <hghklly at gmail.com> a écrit :
> Hi all,
> I have a points dataset with a few null geometries in it.
> Is there a tool that can update these in place?
> It seems that the point editing tool must add a new row instead of
> updating an existing row.
> The vertex editing tool seems unable to update a null geom since there's
> nothing to initially click on.
> Maybe I'm missing a tool or way of using the vertex editing tool?
> A less preferred workflow would be to create a separate file and manually
> add the points with the primary key as an attribute to later update on in
> postgres but it would be much cleaner to edit the table in place I think
> and I am curious if there is a solution since I'm not thinking anything up
> myself.
> Thanks for any suggestions.
> Hugh Kelley
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/6d45e8b3/attachment.html>
