[Qgis-user] Import kml with all the fields
    Camilo Aristizabal
    aristizabalcamilo at ymail.com
    Thu Jan 20 19:11:08 PST 2022
Hello Kryshna There is no reason for to this happen. You just need to add it by clicking on Open Data Source Manager, and then you just look for your KML file, which can be made by point, lines or polygons with huge attributes as a database. But, just be sure you are loading your kml/kmz as a vector file
I hope it helps.
Cheers!
Camilo
    Em quinta-feira, 20 de janeiro de 2022 22:19:46 BRT, krishna Ayyala <ayyalakrishna at gmail.com> escreveu:
 Hello,I have a kml that has a point layer with about 50 Points. Each point has four fields. Field1,Field2,Field3 and Field4. I have imported this kml into qgis. When I open the attribute table, I see only Field1. Is there a way to import the kml so that I can see all the 4 fields in the attribute table?
Regards._______________________________________________
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/bd415707/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/bd415707/attachment-0001.png>
