[Qgis-user] Import kml with all the fields
    Phil Wyatt
    phil at wyatt-family.com
    Thu Jan 20 20:22:58 PST 2022
Hi Kryshna
Its also possible to ‘drag and drop’ the kml from the file manager to the map window. You might also let us know where the kml was created as the error may be from the original source rather than a QGIS issue. Do the other fields show up if opened in Google Earth?
Cheers - Phil
Em quinta-feira, 20 de janeiro de 2022 22:19:46 BRT, krishna Ayyala <ayyalakrishna at gmail.com <mailto:ayyalakrishna at gmail.com> > escreveu:
Hello,
I have a kml that has a point layer with about 50 Points. Each point has four fields. Field1,Field2,Field3 and Field4. I have imported this kml into qgis. When I open the attribute table, I see only Field1. Is there a way to import the kml so that I can see all the 4 fields in the attribute table?
Regards.
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/3cfb3756/attachment.html>
