[Qgis-user] Import kml with all the fields
    krishna Ayyala
    ayyalakrishna at gmail.com
    Thu Jan 20 21:08:15 PST 2022
Phil,
Thanks for the reply. I did drag and drop. But still only "Field1" shows
up in the attribute table. There are other fields such as "description",
"timestamp", "begin", "end" which show in the attribute table. These other
fields are automatically generated when I add kml to the map. But all I am
interested to see are Field1,Field2,Field3 and Field4.. The only useful
filed I see is  Field1. When I open this kmz in google earth and click on
any point, I see all the four fields. Is there a way to see all these four
fields in QGIS?
Regards
On Thu, Jan 20, 2022 at 9:23 PM Phil Wyatt <phil at wyatt-family.com> wrote:
> Hi Kryshna
> Its also possible to ‘drag and drop’ the kml from the file manager to the
> map window. You might also let us know where the kml was created as the
> error may be from the original source rather than a QGIS issue. Do the
> other fields show up if opened in Google Earth?
> Cheers - Phil
> Em quinta-feira, 20 de janeiro de 2022 22:19:46 BRT, krishna Ayyala <
> ayyalakrishna at gmail.com> escreveu:
> Hello,
> I have a kml that has a point layer with about 50 Points. Each point has
> four fields. Field1,Field2,Field3 and Field4. I have imported this kml into
> qgis. When I open the attribute table, I see only Field1. Is there a way to
> import the kml so that I can see all the 4 fields in the attribute table?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/ab1f2070/attachment.html>
