[Qgis-user] Import kml with all the fields
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Thu Jan 20 19:36:42 PST 2022
There is a kml import plugin you can try.  This may help.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 20 janv. 2022 à 20:20, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Hello,
> I have a kml that has a point layer with about 50 Points. Each point has four fields. Field1,Field2,Field3 and Field4. I have imported this kml into qgis. When I open the attribute table, I see only Field1. Is there a way to import the kml so that I can see all the 4 fields in the attribute table?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220120/0f193ecc/attachment.html>
