[Qgis-user] Import kml with all the fields
C Hamilton
adenaculture at gmail.com
Fri Jan 21 04:55:05 PST 2022
Because of the free-form nature of how KMLs can be constructed, they can
sometimes be challenging to interpret. Try the KML Tools plugin
https://plugins.qgis.org/plugins/kmltools/
It uses a different methodology to interpret KML/KMZs than what is in QGIS.
Since I am the author of that plugin, if it does not work send me a copy of
the KML and I will try to make sure it works for your case.
Best wishes,
Calvin
On Thu, Jan 20, 2022 at 8:19 PM krishna Ayyala <ayyalakrishna at gmail.com>
wrote:
> Hello,
> I have a kml that has a point layer with about 50 Points. Each point has
> four fields. Field1,Field2,Field3 and Field4. I have imported this kml into
> qgis. When I open the attribute table, I see only Field1. Is there a way to
> import the kml so that I can see all the 4 fields in the attribute table?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/4b8ad5e5/attachment.html>
