[Qgis-user] Array --> Generate_Series
Miquel Pujol Garcia miquel at adverbiodelugar.international
Fri Jan 21 03:04:55 PST 2022
*Hello Qgisers,*
I'm trying to insert in a field* a serial data number (2,4,6,8,10,...)
using *generate_series* from array group. When I purpose the
syntax in Calculate Camps in the table, I can see the correct
result but when I execute the values aren't inserted in the field.
The objects are lines in a Geopackage.
Does someone use generate_series and know-how run well?
*field = enter number: long 10
Thanks,
*Miquel*
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/c96e6729/attachment.html>
