[Qgis-user] Import kml with all the fields
    Phil Wyatt
    phil at wyatt-family.com
    Thu Jan 20 21:40:39 PST 2022
Is it KML (single file) or KMZ which may contain multiple files? Unzip the KMZ and have a look at the files – maybe there is some way to connect/join the different files via a common field
https://gis.stackexchange.com/questions/365579/showing-images-linked-with-corresponding-kmz-in-qgis
Sent: Friday, 21 January 2022 4:08 PM
To: Phil Wyatt <phil at wyatt-family.com>
Cc: Camilo Aristizabal <aristizabalcamilo at ymail.com>; qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Import kml with all the fields
Phil,
Thanks for the reply. I did drag and drop. But still only "Field1" shows up in the attribute table. There are other fields such as "description", "timestamp", "begin", "end" which show in the attribute table. These other fields are automatically generated when I add kml to the map. But all I am interested to see are Field1,Field2,Field3 and Field4.. The only useful filed I see is  Field1. When I open this kmz in google earth and click on any point, I see all the four fields. Is there a way to see all these four fields in QGIS?
Regards
On Thu, Jan 20, 2022 at 9:23 PM Phil Wyatt <phil at wyatt-family.com <mailto:phil at wyatt-family.com> > wrote:
Hi Kryshna
Its also possible to ‘drag and drop’ the kml from the file manager to the map window. You might also let us know where the kml was created as the error may be from the original source rather than a QGIS issue. Do the other fields show up if opened in Google Earth?
Cheers - Phil
Em quinta-feira, 20 de janeiro de 2022 22:19:46 BRT, krishna Ayyala <ayyalakrishna at gmail.com <mailto:ayyalakrishna at gmail.com> > escreveu:
Hello,
I have a kml that has a point layer with about 50 Points. Each point has four fields. Field1,Field2,Field3 and Field4. I have imported this kml into qgis. When I open the attribute table, I see only Field1. Is there a way to import the kml so that I can see all the 4 fields in the attribute table?
Regards.
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/ca359292/attachment.html>
