[Qgis-user] Import kml with all the fields
krishna Ayyala
ayyalakrishna at gmail.com
Fri Jan 21 09:04:23 PST 2022
Hello,
I am herewith attaching the kmz. When I open this in google earth, I can
see all the four fields;Field1,Field2,Field3 and Field4. But, when I add
this kmz to QGIS and open the attribute table, I cannot see any of these
fields. This is just a sample data. I have about 50 to 60 such kmzs. Can
you please suggest as permanent solution so that I can fix it myself and
see all the four fields?
Regards.
On Thu, Jan 20, 2022 at 10:40 PM Phil Wyatt <phil at wyatt-family.com> wrote:
> Is it KML (single file) or KMZ which may contain multiple files? Unzip the
> KMZ and have a look at the files – maybe there is some way to connect/join
> the different files via a common field
> https://gis.stackexchange.com/questions/365579/showing-images-linked-with-corresponding-kmz-in-qgis
> *From:* krishna Ayyala <ayyalakrishna at gmail.com>
> *Sent:* Friday, 21 January 2022 4:08 PM
> *To:* Phil Wyatt <phil at wyatt-family.com>
> *Cc:* Camilo Aristizabal <aristizabalcamilo at ymail.com>; qgis-user <
> qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Import kml with all the fields
> Phil,
> Thanks for the reply. I did drag and drop. But still only "Field1" shows
> up in the attribute table. There are other fields such as "description",
> "timestamp", "begin", "end" which show in the attribute table. These other
> fields are automatically generated when I add kml to the map. But all I am
> interested to see are Field1,Field2,Field3 and Field4.. The only useful
> filed I see is Field1. When I open this kmz in google earth and click on
> any point, I see all the four fields. Is there a way to see all these four
> fields in QGIS?
> Regards
> On Thu, Jan 20, 2022 at 9:23 PM Phil Wyatt <phil at wyatt-family.com> wrote:
> Hi Kryshna
> Its also possible to ‘drag and drop’ the kml from the file manager to the
> map window. You might also let us know where the kml was created as the
> error may be from the original source rather than a QGIS issue. Do the
> other fields show up if opened in Google Earth?
> Cheers - Phil
> Em quinta-feira, 20 de janeiro de 2022 22:19:46 BRT, krishna Ayyala <
> ayyalakrishna at gmail.com> escreveu:
> Hello,
> I have a kml that has a point layer with about 50 Points. Each point has
> four fields. Field1,Field2,Field3 and Field4. I have imported this kml into
> qgis. When I open the attribute table, I see only Field1. Is there a way to
> import the kml so that I can see all the 4 fields in the attribute table?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/1313ef48/attachment.html>
Type: application/vnd.google-earth.kmz
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220121/1313ef48/attachment.kmz>
