[Qgis-user] Help converting State
tim dunlevie
tim.dunlevie5 at gmail.com
Tue Jan 25 03:48:09 PST 2022
Yeah I do a "long way" around for this.
Add the layer - add delimited text layer....(or use the geoprocessing task)
Plot those points in its original projection.
Export that layer to the new grid / projection you want to generate the
coordinates.
Add new fields to this new layer, then use field calculator to generate XY
($x, $y in field calculator).
On Tue, 25 Jan 2022, 7:41 pm Nicolas Cadieux, <njacadieux.gitlab at gmail.com>
wrote:
> Hi Doug.
> QGIS will reproject the data on the fly so you will not “see” (on the
> screen) the difference. Try saving the reprojected file as a .gpkg then use
> the field calculator to create a new x and y field. That should generate
> new x and y coordinates in the new CRS.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 24 janv. 2022 à 19:00, Bighouse Productions <
> doug at bighouseproductions.ca> a écrit :
> Bighouse Productions <doug at bighouseproductions.ca>
> [image: Attachments]3:44 PM (12 minutes ago)
> to chris, qgis-user
> Thanks so much Chris,
> I've been trying 6.1.3 for a while now and I can't seem to get the CSV
> file to export & convert from one CRS to the other (NAD27 Nevada East to
> UTM NAD27).
> No probs switching the CRS of the document and the coordinates layer...
> but each time I export in the new CRS (EPSG:26711) the saved document is
> exactly as it was when I started. To summarize, here's what I'm doing:
> 1. Start a new QGIS file
> 2. Change the CRS to Nevada East NAD27
> 3. Add comma delimited layer & change x to East and y to northing
> Everything looks good at this point. Now I just want to convert from NAD27
> Nevada East to NAD 27 UTM... no luck.
> From here I've tried a few things:
> 1. Export this layer to EPSG:26711. Nothing changes.
> 2. Change project and layer CRS to EPSG:26711 and export as EPSG:26711.
> Nothing changes.
> 2. Various other implementations of the above.
> Do you see what I'm doing wrong? I'll paste a link to the file just in
> case you have a chance to have a look at it. Thanks again.
> https://drive.google.com/file/d/1TsOyNMLqGD8MsnT-UpirMjw7gXxw1_43/view?usp=sharing
> Doug.
> *Doug Hadfield, *
> *bighouseproductions.ca <http://bighouseproductions.ca/>*
> *VRtuous.com <http://www.vrtuous.com/>*
> *virtualvideoproductions.com <http://virtualvideoproductions.com>*
> *Video, Animation, Photography, 3D & VR*
> 778 895 1755
> Demo Reel: https://vimeo.com/183084451
> Photography: bighouse.smugmug.com
> On Mon, Jan 24, 2022 at 1:58 PM chris hermansen <clhermansen at gmail.com>
> wrote:
>> Ooops sorry I only responded to the OP
>> On Mon, Jan 24, 2022 at 1:57 PM chris hermansen <clhermansen at gmail.com>
>> wrote:
>>> Doug and list,
>>> On Mon, Jan 24, 2022 at 1:49 PM Bighouse Productions <
>>> doug at bighouseproductions.ca> wrote:
>>>> Hi there, I'm hoping someone can help me convert State Plane
>>>> Coordinate System, Nevada East NAD27 to UTM NAD27 using QGIS. I have a CSV
>>>> spreadsheet with 1000s of drill holes with Easting and Northing data in
>>>> SPCS Nevada East. Is this doable using QGIS?
>>>> Thanks for any help you can provide!
>>> It sounds like you have point data in a .csv file.
>>> QGIS has lots of great documentation that can help you do this kind of
>>> task. For example, you might want to read over this on using spreadsheet
>>> or csv data:
>>> https://www.qgistutorials.com/en/docs/importing_spreadsheets_csv.html
>>> and then this on reprojecting
>>> https://docs.qgis.org/3.16/en/docs/training_manual/vector_analysis/reproject_transform.html
>>> especially 6.1.3
>>> Chris Hermansen · clhermansen "at" gmail "dot" com
>>> C'est ma façon de parler.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220125/3b295249/attachment.html>
