[Qgis-user] Add elevation data to many gpx files
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Jan 25 09:03:06 PST 2022
Gdal, a core library of QGIS can read and write to gpx. I did not play much with this format but it does support xyz points. I would import the gpx file, save as .shp. Use a Dem like NASADEM to get the elevations (you have multiple tools and plugins that can make a point sampling from a raster) and then save to gpx.
You could create a model to accelerate the process. You can then batch this model in “processing”.
https://gdal.org/drivers/vector/gpx.html
Look for gpx or gps in the plugins, you will probably find interesting tools there.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 25 janv. 2022 à 09:03, APM <apschwimmer at apmland.de> a écrit :
> Dear List,
> is it possible to add elevation data to gpx files with Qgis?
> I have a high amount of gpx-files and would have to add the data's in a batch.
> Thank you!
> Kind regards
> Piet
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220125/0f4b8d48/attachment.html>
