[Qgis-user] pull data from geoserver
Ian Turton
ijturton at gmail.com
Wed Jan 26 07:06:30 PST 2022
It looks like they have set a proxy url in the global settings
<ows:Operation name="DescribeFeatureType">
<ows:DCP>
<ows:HTTP>
<ows:Get xlink:href="https://gis.drcog.org/wfs"/>
<ows:Post xlink:href="https://gis.drcog.org/wfs"/>
</ows:HTTP>
</ows:DCP>
But that URL doesn't answer requests (curl '
https://gis.drcog.org/wfs?SERVICE=WFS&REQUEST=DescribeFeatureType&VERSION=2.0.0&TYPENAMES=DRCOGPUB:bridges_low_clearance&TYPENAME=DRCOGPUB:bridges_low_clearance'
-H 'User-Agent: Mozilla/5.0 QGIS/32203' --compressed) - I can highly
recommend the QGIS Network Logger plugin to investigate this sort of issue.
While
https://gis.drcog.org/geoserver/ows?service=wfs&REQUEST=DescribeFeatureType&VERSION=2.0.0&TYPENAMES=DRCOGPUB:bridges_low_clearance&TYPENAME=DRCOGPUB:bridges_low_clearance
does
work there's no easy way to get QGis to use this URL.
It's odd that the WFS connection manager lacks the `ignore URL in
capabilities` option that WMS has that would let you get around this sort
of misconfigured server.
I've copied in the contact from the capabilities doc in the hope they can
fix it.
Ian
On Wed, 26 Jan 2022 at 13:41, Hugh Kelley <hghklly at gmail.com> wrote:
> Hi all,
> hoping I'm missing something as I'm trying to pull data from a geoserver
> [0] into QGIS and eventually grab it with ogr2ogr.
> I've tried following these instructions [1], but haven't figured out what
> I'm doing wrong and they're fairly old.
> The latest geoserver WFS version available from that endpoint is 2.0. Is
> it possible that version is too old for compatibility with QGIS 3.20.3?
> Maybe there's a setting I'm missing when adding the WFS or that it's not a
> WFS that I should be adding?
> when i try to add a dataset the datasource manager gives the error:
> Layer is not valid: The layer pagingEnabled='false'
> preferCoordinatesForWfsT11='false' srsname='EPSG:6428'
> typename='DRCOGPUB:rtd_brt_network' url='
> https://gis.drcog.org/geoserver/ows' url='
> https://gis.drcog.org/geoserver/ows?version=2.0.0' version='2.0.0' is not
> a valid layer and can not be added to the map. Reason:
> (end of error message, the "reason" is left blank)
> to me that looks as though the url is being built incorrectly.
> when I paste:
> https://gis.drcog.org/geoserver/ows?service=wfs&version=2.0.0&request=GetCapabilities
> into the url box, QGIS is switching that to :
> thanks for any thoughts or suggestions. I was pleased to see an
> organization using open source instead of the esri cloud services that I
> see more frequently so hopefully this is something I can figure out.
> Hugh
> [0]: https://gis.drcog.org/geoserver/web/
> [1]: https://www.lifeingis.com/adding-layers-from-geoserver-in-qgis/
> Hugh Kelley
> Qgis-user mailing list
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220126/1a7db2fe/attachment.html>
