[Qgis-user] Print formatting style
Thayer Young
thayeray at yahoo.com
Wed Jan 26 11:09:45 PST 2022
Hi Lars,
The tutorial linked below will guide you through the steps you are looking for. Briefly you want to make an atlas (3 steps) using your polygon layer, use inverted polygon styling for your polygons, and set the style to be rule based to select only the current atlas feature: $id = @atlas_featureid
https://www.qgistutorials.com/en/docs/3/automating_map_creation.html
-Thayer
On Wednesday, January 26, 2022, 03:30:44 AM EST, <qgis-user-request at lists.osgeo.org> wrote:
> Date: Tue, 25 Jan 2022 23:49:12 +0100
> From: Lars Bendix <lars.bendix.de at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Print formatting style
> Message-ID:
<CADjZRrxqKFZaCN4+kRCftmFRqNwvweac6-18=H4fSADB2JgN=Q at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hello, I'm using QGIS LTS 3.16 Windows 10. I would have the following
> question:
> I have imported a kml layer with polygon objects on a streetmap.
> I would like to print one map page for each polygon object. My problem is
> the following: which format style should I choose, so that each print page
> only shows the current polygon object on the map and not the neighbor
> polygon objects? And how can I format it inverted, so that everything
> outside the polygon object border is shown in grey on the print page? Thank
> you!
> Lars
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220126/13fb45eb/attachment.html>
