[Qgis-user] Drop the points and show only clusters
krishna Ayyala ayyalakrishna at gmail.com
Sat Jan 29 09:36:27 PST 2022
Dear Simon,
Thanks for your reply. I have used the "overlay_nearest" formula for my
points layer. Irrespective of whatever number I assign for "max_distance" I
am getting the value 1 for the new field for all the 1000 records of the
points layer. i.e. I am not getting 0 value for any of the records. I tried
for various distances starting from 1 upto 1000. For ex:1,5,10,100,500,1000
etc. My map units are set to meters.
Regards.
[image: image.png]
On Fri, Jan 28, 2022 at 1:53 AM Simon Dietmann <simon.dietmann at pgnu.de>
wrote:
> Hi Krishna,
> you could also use the field calculator to create a Boolean field with the
> overlay_nearest function, like:
> overlay_nearest( '<name_of_same_point_layer>' ,  max_distance:= 1000)
> This will generate a field that contains a ‘1’ if the point has a
> neighbour within the given distance and a ‘0’ if not. Then show only points
> that have a ‘1’ in this field.
> Greetings,
> Simon
> *Von:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *Im Auftrag von *krishna
> Ayyala
> *Gesendet:* Freitag, 28. Januar 2022 05:12
> *An:* qgis-user <qgis-user at lists.osgeo.org>
> *Betreff:* Re: [Qgis-user] Drop the points and show only clusters
> Helo
> I watched the video in the weblink below. I was able to get up to the
> layer styling step. But,I am unable to figure out how to accomplish this
> task. I am herewith attaching the sample data of 1000 points.  Can anyone
> please guide me the steps so that  I will have  only those points that are
> within 1000ft of each other and drop the rest of the points?
> Regards.
> https://anitagraser.com/2017/06/13/even-more-aggregations-qgis-point-cluster-renderer/
> On 28/01/22 09:25, krishna Ayyala wrote:
> > Hello,
> > I have a point shape with about 10,000 points. On the map, I wish to
> > show only those points that are within 1000ft of each other and drop
> > the rest of the points. All I am trying to see is only the clusters.
> > Can anyone help please?
> > Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220129/6bf0ce54/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220129/6bf0ce54/attachment-0001.png>
