[Qgis-user] Drop the points and show only clusters
Simon Dietmann
simon.dietmann at pgnu.de
Fri Jan 28 00:53:20 PST 2022
Hi Krishna,
you could also use the field calculator to create a Boolean field with the overlay_nearest function, like:
overlay_nearest( '<name_of_same_point_layer>' , max_distance:= 1000)
This will generate a field that contains a ‘1’ if the point has a neighbour within the given distance and a ‘0’ if not. Then show only points that have a ‘1’ in this field.
Greetings,
Simon
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von krishna Ayyala
Gesendet: Freitag, 28. Januar 2022 05:12
An: qgis-user <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Drop the points and show only clusters
Helo
I watched the video in the weblink below. I was able to get up to the layer styling step. But,I am unable to figure out how to accomplish this task. I am herewith attaching the sample data of 1000 points. Can anyone please guide me the steps so that I will have only those points that are within 1000ft of each other and drop the rest of the points?
Regards.
https://anitagraser.com/2017/06/13/even-more-aggregations-qgis-point-cluster-renderer/
On 28/01/22 09:25, krishna Ayyala wrote:
> Hello,
> I have a point shape with about 10,000 points. On the map, I wish to
> show only those points that are within 1000ft of each other and drop
> the rest of the points. All I am trying to see is only the clusters.
> Can anyone help please?
> Regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220128/6901ffcc/attachment.html>
