[Qgis-user] Interpolation analyses
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Thu Jun  9 12:40:06 PDT 2022
I removed your image as the user group was blocking it.
On 2022-06-09 3:29 p.m., Nicolas Cadieux wrote:
> I Forgot to add the user list...
> On 2022-06-09 3:27 p.m., Nicolas Cadieux wrote:
>> Hi,
>> Notice the selection box besides "Précision".  You will see "Estimée
>> (plus rapide)", Change that to "Actual (slower)". Then, if you choose
>> min/max, you should see the correct values.  If you don't see the
>> correct min-max value, open processing/Raster information/ select
>> "Force computation of the actual min/max values for each band".  add
>> -stats in the additional command-line parameters.
>> Bonne Chance
>> Nicolas Cadieux
>> On 2022-06-09 11:46 a.m., Thibaut Bouveroux wrote:
>>> Hi Nicolas,
>>> Thanks a lot for your help. I am using the QGIS idk interpolation. I
>>> think I figured out a way to get the results fitting my data
>>> adjusting min and max values from the dataset. When I get the
>>> output, I can change the min and max values in the symbology tab. Is
>>> that the way you would recommend?
>>> Thanks a lot for your assistance.
>>> Best,
>>>> Le 9 juin 2022 à 10:32 AM, Nicolas Cadieux
>>>> <njacadieux.gitlab at gmail.com> a écrit :
>>>> Hi,
>>>> It would help if you gave what algorithms you are using.  There is
>>>> a Gdal and a QGIS idw interpolation method and they are not working
>>>> the same way.  Also, QGIS has a quick way of determining the min
>>>> max value that are an estimate of the true values.  Use Gdal info
>>>> with flag -stats to get the true values.  You will find that in the
>>>> processing plugin.
>>>> https://gdal.org/programs/gdalinfo.html
>>>> Nicolas Cadieux
>>>> https://gitlab.com/njacadieux
>>>>> Le 9 juin 2022 à 10:33, Thibaut Bouveroux via Qgis-user
>>>>> <qgis-user at lists.osgeo.org> a écrit :
>>>>> Hi everyone,
>>>>> I am trying to make an IDW interpolation analyses using salinity
>>>>> data in a bay. My values ranges between 0.1 to 13.1 PSU. When
>>>>> making my interpolation with 148 data points, the interpolation
>>>>> output ranges between 0.0034 to 12.40 and so doesn't fit 100% with
>>>>> the dataset. Can someone has na idea why? Using the same data set
>>>>> in ArcMap, the interpolation I made ranged between 0.1 and 13.1
>>>>> and does fit 100% with my dataset.
>>>>> Thanks a lot for your assistance,
>>>>> Best,
>>>>> Thibaut
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Nicolas Cadieux
> Nicolas Cadieux
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220609/d6092540/attachment.htm>
