[Qgis-user] Symbology
Allan Younger
ahyounger at iinet.net.au
Fri Jun 17 23:13:04 PDT 2022
csv file
------ Original Message ------
>From "Kobben, Barend (UT-ITC)" <b.j.kobben at utwente.nl>
To "chris hermansen" <clhermansen at gmail.com>; "Allan Younger"
<ahyounger at iinet.net.au>
Cc "QGIS User" <Qgis-user at lists.osgeo.org>
Date 18/06/2022 12:32:07 PM
Subject Re: [Qgis-user] Symbology
>Usually this happens if you have numbers (quantitatvie data) that are
>stored in your file/db as Strings (text)....
>Barend Köbben
>On 18/06/2022, 04:25, "Qgis-user on behalf of chris hermansen via
>Qgis-user" <qgis-user-bounces at lists.osgeo.org on behalf of
>Qgis-user at lists.osgeo.org> wrote:
>Allan and list,
>On Fri, Jun 17, 2022 at 7:00 PM Allan Younger via Qgis-user
><qgis-user at lists.osgeo.org> wrote:
>>Hi,
>>I'm trying to show assay results as simple dot plots as graduated
>>colour and size scaled points based on a selected element.
>>Problem is that in the layer properties/symbology tab, I cannot select
>>anything.
>>Had the problem in Madeira 3.4 & assumed was just a glitch that had
>>developed in that copy over time.
>>Installed 3.22.7, same problem.
>>Csv file has 162000 records & 30 column with co-ords for every point;
>>with locations plotting a-ok.
>At the top of the Layer Properties > Symbology dialogue window, have
>you selected one of the options other than "No Symbols"? For example,
>"Graduated"?
>Then in the field Value one of your layer's attributes?
>Then pressed the "Classify" button?
>Chris Hermansen · clhermansen "at" gmail "dot" com
>C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220618/75810ccd/attachment.htm>
