[Qgis-user] Polar stereographic (0 - 360 longitudes)
Brent Wood Brent.Wood at niwa.co.nz
Sun Jun 19 16:51:28 PDT 2022
I don't believe you can.
The underlying proj libraries (as used by QGIS) no longer support longitudes > 180 by default, so any re-projection from EPSG:4326 will only work with +-180 longitudes.
There isa command line parameter (+over) which can be used with proj on the command line but I don't think this is supported by QGIS.
If you use Postgis (or Spatialite), there is an ST_ShiftLongitude() function that will switch +-180 to 0-360 or the reverse which makes the operation pretty trivial for any sort of geometry.
I have created a custom QGIS/Postgis projection (many years ago) which I assigned a code of 4327, this was essentially 4326 in a 0-360 degree space, so I could reproject between them, I'm not sure if this is still possible with the latest versions of proj with wkt definitions.
Brent Wood
Principal Technician, Fisheries
NIWA
DDI:  +64 (4) 3860529
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> on behalf of Lester Anderson via Qgis-user <qgis-user at lists.osgeo.org>
Sent: Sunday, June 19, 2022 22:16
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Polar stereographic (0 - 360 longitudes)
Hi all,
I have data which is in 0-360 degree longitudes and I would like to apply a Polar stereographic projection. However, since the EPSG 3995 has limits of -180/+180 for longitude, as expected it gives half the plot.
For some reason I cannot create a custom projection with an extent such as:
xmin=0, xmax=360, ymin=60, ymax=90 based on 3995 even removing reference to this ID.
Any ideas how to proceed without having to shift it all to +/- 180
Tested in 3.20 and 3.24
Thanks
Lester
[https://www.niwa.co.nz/static/niwa-2018-horizontal-180.png] <https://www.niwa.co.nz>
Brent Wood
Principal Technician - GIS and Spatial Data Management
Programme Leader - Environmental Information Delivery
+64-4-386-0529
National Institute of Water & Atmospheric Research Ltd (NIWA)
301 Evans Bay Parade Hataitai Wellington New Zealand
Connect with NIWA: niwa.co.nz<https://www.niwa.co.nz> Facebook<https://www.facebook.com/nzniwa> LinkedIn<https://www.linkedin.com/company/niwa> Twitter<https://twitter.com/niwa_nz> Instagram<https://www.instagram.com/niwa_science>
To ensure compliance with legal requirements and to maintain cyber security standards, NIWA's IT systems are subject to ongoing monitoring, activity logging and auditing. This monitoring and auditing service may be provided by third parties. Such third parties can access information transmitted to, processed by and stored on NIWA's IT systems
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220619/bac5de7a/attachment.htm>
