[Qgis-user] polygon fills from different shapefiles
Sebastian Gutwein bas at rdgland.com
Tue Jun 21 13:37:59 PDT 2022
And even easier is to put them all in a group then copy the style from one
layer and paste it onto the group. This will apply the style to all layers
in the group.
On Tue, Jun 21, 2022 at 3:22 PM Thayer Young via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> A method that is a little easier than saving out the style file, is that
> you can just right click on the layer that you styled, then third from the
> bottom in the menu select:   Styles: Copy Style: All Style Categories
> And then you can paste the style to the rest of your layers using:
> Styles: Paste Style: All Style Categories
> -Thayer
> On Tuesday, June 21, 2022 at 03:00:36 PM EDT,
> qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org>
> wrote:
> i have four different geologic maps that i have imported as shapefiles.
> The files have filled polygons that have the name of the geologic formation
> in the attribute tables.  i would like to have a common colour for each
> polygon of identical age/name for all the map sheets.  Each map sheet has a
> similar list of formations, but some of the formations are different for
> each map sheet.
> What is the most efficient way to make the identically named polygons
> displayed with the same colour?  Should i add a column in each attribute
> table and put a formation code in for each one manually or can i add an RGB
> colour for each formation in the attribute table? or, do i need to
> categorize and  classify these in the layer properties table after i have
> added formation code in the attribute table?
> i hope that my question is clear.
> Byron Veilleux, MSc. P.Geo
> Conjugate Geologic Services Limited
> Calgary, Alberta Canada
> byron at conjugategeo.com
> Cell:4037108414
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220620/c8b38539/attachment-0001.htm
> Qgis-user mailing list
___________________________
Sebastian "Bas* " Gutwein
*rhymes with Josh
Regenerative Design Group
1 Chevalier Ave
Greenfield, Ma 01301
Web: regenerativedesigngroup.com
(631) 241-1018
*Look close, think big, make change. *
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220621/c4cab681/attachment.htm>
